6.4 UPDATE
MSGTRETIREDCSP
Well I received word from the Ford garage that my problem is a left side head gasket, NOT an egr cooler. Parts are on order and should re repaired by next Wednesday. Will keep you advised if anything else developes. Thanks again for all the replies, I really appreciate it. Safe travels.
2016 RAM Tradesman, 3500, DRW, 3:73, B & W hitch.
2007 Select Suites 5th Wheel
43 REPLIES 43
MSGTRETIREDCSP
WhitehouseLV wrote:
I have a 2008 F350 w/176k. How much is your repair bill going to be?
Well, itS not as bad as it could have been. Going to cost $3400.00. That's for one side only. The parts alone cost $1200.00.
rhagfo
Hoping for an update tomorrow, did you have both HG done of just the necessary repairs?
WhitehouseLV
Longtime Member of RV.net (since 2005) just trying to find my friends and way around in this new community.
40' Keystone Toyhauler
2017 Ram 3500 DRW
2019 KTM 300 XC-W tpi
Honda CRF 80F
Honda Rincon
Polaris RZR 800 Trail
OH48Lt
I'd trade that 6.4 right at the dealer, let them assume the repair $$$ (they'll take it out on your trade-in value, but not nearly as much as what you'll pay to fix it and then trade it). Get a nice 6.7 and move on down the road. MUCH better engine.
2017 Ford F-150 Crew Cab 4x4 3.5 EcoBoost
2014 Cruiser RV Fun Finder 215WKS
2015 Harley Road Glide Special in Amber Whiskey
2019 Mustang Bullitt
Yamaha Grizzly 660 (his)
Polaris Sportsman 500 H.O.(hers)
jerem0621
Fast Mopar wrote:
Wizbangdoodle wrote:
I was faced with this dilemma last year. An injector stuck open, melted a piston and damaged a cylinder. I had to chose between a new truck or fixing the old one. Considering the price of a new truck, I chose to fix my truck. I spent about $16k and that is doing the work myself, but I have it built exactly how I want it.
Wow, $16,000 for the repair and that was doing the work yourself. And, that does not include any other things that can go wrong on an older truck (transmission, differential, electrical issues, suspension issues). That's too rich for me. Guess I will just keep driving my cheap vehicles. But, I'm glad others can afford those types of repairs.
X2...love my chosen TV
TV-2022 Silverado 2WD
TT - Zinger 270BH
WD Hitch- HaulMaster 1,000 lb Round Bar
Dual Friction bar sway control
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
Fast_Mopar
2013 Dodge Grand Caravan
2009 Chevy Cobalt XFE
2004 Ford Freestar 4.2 liter
2003 Jayco Qwest 12A
ex: 1969 Dodge Super Bee, 1973 Plymouth Road Runner, 1987 Dodge Shelby CSX
preserve the Second Amendment
blofgren
mtofell1 wrote:
RAS43 wrote:
phillyg wrote:
Isn't the stretching stud problem limited to the 6.0 engines?
I am also scratching my head about this discussion. Seems like a lot of confusion between 6.0 and 6.4 issues. Even one responder mentioned the repairs to his 6.0 and the OP has a 6.4. :h
I think the 6.0 was brought up to show a pattern of problems with Ford diesels. It's seems pretty relevant to the thread.
Exactly right. I'm well aware of the differences between the 6.0 and 6.4. Fact is that they BOTH have much less than stellar reputations and are both well known for very expensive repairs. Anyone who thinks these engines are even in the same league as the other offerings of the day are truly kidding themselves. Yes one can have issues with any diesel but the issues with these engines are much more plentiful and common with these engines.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
MSGTRETIREDCSP
jerem0621 wrote:
Thanks for the update... I am curious as to why the HG failed. Something lifted the head off the block.
Thanks!
Jeremiah
I have no idea. I discussed this with the ford people and they didn't know either. They said it's not common on the 6.4, but it does happen.
Wizbangdoodle
I'll agree with most of what Grit Dog said.
The 7.3 was a fantastic engine and would go 400k easily. Then came the 6.0. It exists because the 7.3 could not meet EPA requirements. It was rushed and engineered poorly. The 6.4 was brought along to address the 6.0's weak points, it was a bandaid fix at best and Ford was already planning the 6.7 at this point.
Yes, the 6.4 has to be properly "modded" to really be reliable, although I have heard of several "bone stock" trucks going 2-300k.
OP will have this decision to make. Keep in mind, this can happen to ANY diesel.
'17 F450 CCLB Platinum dually
jerem0621
Thanks!
Jeremiah
TT - Zinger 270BH
~Walt Disney~
mtofell1
RAS43
phillyg
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
mich800
Several pieces of good advice here. I would also suggest, while the cab is off, get studs and do both head gaskets.
I also agree with what was said above, any brand modern diesel is going to have problems. It is their battle with trying to meet government regulations. The 6.4 gets a pretty bad rap, but once they are modded, I'd put one up against any brand for longevity and durabilty. Good luck and safe travels.
"Once they are modded."
Keep defending fomoco Diesel engines. But show me any other high pressure diesel from the last 15 years that needs 5 grand in internal mods just to make it down the road in stock trim under 100kmi besides the 6.0 and 6.4?
Powderchokes blowing head gaskets has exactly zero to do with the epa unless you're blaming them for limiting what Ford was able to use for head bolts and gaskets.
The guy above I quoted is spot on, in that they're decent engines once fixed and the wrapper around them is good, so decision boils down to how much you want to spend on it.
I agree the 6.7s appear to be better engines and their fast as stink in stock trim, but it took them until last year to catch up to the other 2 with a real exhaust brake.
Anyway to the op, not enough informed buyers to get your money out of head studs if you're dumping it right away. Get it fixed and hang a for sale sign in the window on the trip home!
If you plan on keeping it, follow advice above and get some arp studs and do both sides. May as well do all the bullet proofing and get it over with if your keeping it.
Remember, 07.5 to '11 for Ferd and GM and up til '13 in Dodges are all sort of the bastard children of the diesel world unless you want to delete and spend some money.
Highest failure rate of emissions, poor fuel economy, etc due to the epa.
If you're selling, consider, pre 08 emissions or newer def trucks.
Who says they (at least the 6.4) need internal mods to make it past 100k. A little hyperbole maybe. I am pushing 200k on my 2008 with no internal mods.
Cummins12V98
Cummins12V98 wrote:
While they have the cab off I would highly recommend replacing both head gaskets and studding them!
I'm not sure l'll be keeping the truck now. Will see how much extra for the other head gasket. What's studding?
You have been told what they are. As mentioned new head bolts will cost a certain amount so for resale value alone get the studs and do both gaskets. Mentioning new head gaskets and studs will get you more on a sale.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
