Apr-09-2016 06:25 AM
Apr-09-2016 01:59 PM
Wizbangdoodle wrote:
Several pieces of good advice here. I would also suggest, while the cab is off, get studs and do both head gaskets.
I also agree with what was said above, any brand modern diesel is going to have problems. It is their battle with trying to meet government regulations. The 6.4 gets a pretty bad rap, but once they are modded, I'd put one up against any brand for longevity and durabilty. Good luck and safe travels.
Apr-09-2016 01:00 PM
Apr-09-2016 09:53 AM
Cummins12V98 wrote:
While they have the cab off I would highly recommend replacing both head gaskets and studding them!
Apr-09-2016 09:47 AM
Apr-09-2016 09:31 AM
Apr-09-2016 09:07 AM
MSGTRETIREDCSP wrote:dodge guy wrote:
Good to hear.....I guess. glad they found the issue.
My wife keeps telling me it`s time for a new truck. I keep telling her no! and these newer trucks are the reason why. I may just do a front end update on my X and keep on enjoying it!
Good luck!
I here ya. I'll stay with diesel just because of the rig I tow. I may think about a brand change?
Apr-09-2016 08:56 AM
MSGTRETIREDCSP wrote:Just my opinion here, but why change brands? Go with what you like, but you will not find a truck from ANY manufacturer that does not have problems or issues with something. As for Ford, the new 6.7 Scorpion diesel is getting good reviews from the field. If I could afford one, I would have one. But I will stick with my current truck, currently working its way up to 300,000 miles on the original engine, having only replaced the thermostats and radiator.dodge guy wrote:
Good luck!
Apr-09-2016 08:51 AM
MSGTRETIREDCSP wrote:Removing the head gasket on one side of the engine, while it may be cheaper, would not be a good idea in my humble opinion. Better to replace both sides. The replacement gaskets are frequently better than the original. Since the truck will already be apart, it shouldn't cost that much more. The expense in replacing head gaskets isn't the complexity of the job, but all of the things you need to remove to GET to the head gaskets.Cummins12V98 wrote:
I'm not sure l'll be keeping the truck now. Will see how much extra for the other head gasket. What's studding?
Apr-09-2016 08:35 AM
Good luck!
Apr-09-2016 07:38 AM
spoon059 wrote:
Were you able to get home with truck and camper for this diagnosis? Glad damage isn't too severe, hopefully everything else is mechanically sound and you can keep on trucking with what you've got!
Apr-09-2016 07:37 AM
Apr-09-2016 07:25 AM
Apr-09-2016 07:18 AM
Apr-09-2016 06:45 AM
