Apr-09-2016 06:25 AM
Apr-12-2016 08:08 AM
WhitehouseLV wrote:MSGTRETIREDCSP wrote:
Well I received word from the Ford garage that my problem is a left side head gasket, NOT an egr cooler. Parts are on order and should re repaired by next Wednesday. Will keep you advised if anything else developes. Thanks again for all the replies, I really appreciate it. Safe travels.
I have a 2008 F350 w/176k. How much is your repair bill going to be?
Apr-12-2016 06:49 AM
Apr-10-2016 09:15 PM
Apr-10-2016 07:33 PM
Apr-10-2016 10:23 AM
Fast Mopar wrote:Wizbangdoodle wrote:
I was faced with this dilemma last year. An injector stuck open, melted a piston and damaged a cylinder. I had to chose between a new truck or fixing the old one. Considering the price of a new truck, I chose to fix my truck. I spent about $16k and that is doing the work myself, but I have it built exactly how I want it.
Wow, $16,000 for the repair and that was doing the work yourself. And, that does not include any other things that can go wrong on an older truck (transmission, differential, electrical issues, suspension issues). That's too rich for me. Guess I will just keep driving my cheap vehicles. But, I'm glad others can afford those types of repairs.
Apr-10-2016 09:57 AM
Apr-10-2016 08:54 AM
mtofell1 wrote:RAS43 wrote:phillyg wrote:
Isn't the stretching stud problem limited to the 6.0 engines?
I am also scratching my head about this discussion. Seems like a lot of confusion between 6.0 and 6.4 issues. Even one responder mentioned the repairs to his 6.0 and the OP has a 6.4. :h
I think the 6.0 was brought up to show a pattern of problems with Ford diesels. It's seems pretty relevant to the thread.
Apr-10-2016 08:51 AM
jerem0621 wrote:
Thanks for the update... I am curious as to why the HG failed. Something lifted the head off the block.
Thanks!
Jeremiah
Apr-09-2016 11:08 PM
Apr-09-2016 10:38 PM
Apr-09-2016 10:27 PM
Apr-09-2016 07:17 PM
Apr-09-2016 04:00 PM
Apr-09-2016 03:23 PM
Grit dog wrote:Wizbangdoodle wrote:
Several pieces of good advice here. I would also suggest, while the cab is off, get studs and do both head gaskets.
I also agree with what was said above, any brand modern diesel is going to have problems. It is their battle with trying to meet government regulations. The 6.4 gets a pretty bad rap, but once they are modded, I'd put one up against any brand for longevity and durabilty. Good luck and safe travels.
"Once they are modded."
Keep defending fomoco Diesel engines. But show me any other high pressure diesel from the last 15 years that needs 5 grand in internal mods just to make it down the road in stock trim under 100kmi besides the 6.0 and 6.4?
Powderchokes blowing head gaskets has exactly zero to do with the epa unless you're blaming them for limiting what Ford was able to use for head bolts and gaskets.
The guy above I quoted is spot on, in that they're decent engines once fixed and the wrapper around them is good, so decision boils down to how much you want to spend on it.
I agree the 6.7s appear to be better engines and their fast as stink in stock trim, but it took them until last year to catch up to the other 2 with a real exhaust brake.
Anyway to the op, not enough informed buyers to get your money out of head studs if you're dumping it right away. Get it fixed and hang a for sale sign in the window on the trip home!
If you plan on keeping it, follow advice above and get some arp studs and do both sides. May as well do all the bullet proofing and get it over with if your keeping it.
Remember, 07.5 to '11 for Ferd and GM and up til '13 in Dodges are all sort of the bastard children of the diesel world unless you want to delete and spend some money.
Highest failure rate of emissions, poor fuel economy, etc due to the epa.
If you're selling, consider, pre 08 emissions or newer def trucks.
Apr-09-2016 02:19 PM
MSGTRETIREDCSP wrote:Cummins12V98 wrote:
While they have the cab off I would highly recommend replacing both head gaskets and studding them!
I'm not sure l'll be keeping the truck now. Will see how much extra for the other head gasket. What's studding?
