Awning needs a good cleaning
tjw0099
Hello,
We just purchased a 2006 Jayco Jayflight 25' Travel Trailer and the awning needs cleaning.
I am planning on doing that this weekend.
The condition is good with no rips or tears. Its a manual awning and the frame is solid.
Can I use Dawn dish detergent with a long handled scribe brush?
Is power washing it OK?
I will do both top and under side and let it dry before rolling it back up.
All input is greatly appreciated.
Tom in Gloucester, Va
The 2006 Jayco Jayflight
15 REPLIES 15
CashandCompany
I'll chime in for using the Mr. Clean sponge. I bought the mop one, which comes on a long handle. Let me tell you... no scrubbing or elbow grease needed. It is such a simple solution, we wonder why we ever did all of that scrubbing. LOL
Mr__C
Do not use Zep mold and mildew cleaner...:S
2020 Keystone Cougar 26RBS "Pressure Relief 4"
2017 Silverado LTZ 6.2 4x4
MM2 USN 1970-75
USS Canisteo AO-99
USS Miller DE-1091
"Knowledge is good". Emil Faber
oughtsix
Maybe your awning isn't as dirty as mine was but I had to do some serious scrubbing after rolling it up and letting it sit for a while. I highly recommend getting a revolver brush and using it for scrubbing:
http://www.amazon.com/Revolver-DrillBrush01-Drill-Brush/dp/B002DLRN72/ref=sr_1_1?ie=UTF8&qid=1412300...
I have had mine for over a year and it holds up very well, it hasn't lost but a couple bristles after a lot of use.
It also works great for showers, sinks and even bug guts!
2006 Duramax Crew Cab Long Bed pickup.
2007 Coachman Captiva 265EX trailer.
rbrumm
Glad I read this post, I wondered what I should use too.
2011 Ram Outdoorsman
2014 Rockwood 2909SS Emerald Package
D_and_A_plus_6
I use Mean Green straight, rinse off, let dry and use 303 Aerospace Protectant. Helps to keep clean longer and prevent mildew.
Terryallan
camp-n-family wrote:
Something I find works well is the hose down the awning and brush it lightly with your cleaning solution. Leave it on and roll it up. Give it a half hour to work its majic and then unroll. Any dirt and mildew will be easier to clean off.
Yep. Easiest way to clean it.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Drbolasky
I use a mixture of water, some bleach and Simple Green. Very effective.
Doug, Linda, Audrey (USN) & Andrew
2008 Sequoia SR-5, 5.7 L, 2000 Coachmen Futura 2790TB Bunkhouse, Dexter E-Z Flex Suspension, Reese W.D. Hitch/Dual Cam Sway Control, Prodigy Brake Controller, McKesh Mirrors
:B
Mark_and_Linda
Don't forget to check your strap if you have one. I had one break as I was pulling mine down last year.
Mark
CaveRun
I use dawn and a soft brush with a long handle... I roll out my awning and let it all the way down.
If I have some spots that are hard to get off, then I spray some ''Purple Power'' on the spots and they come off very easy!
John 3:16
1996 Hide Away Sun Lite Truck Camper
2003 31' Salem LE Forest River Travel Trailer
2013 Sun Tracker Bass Buggy 18 DLX Pontoon
2002 F-150 SuperCab V-8 4X4
Firestone Air Bags
Homemade Tie Down Mounts
Equal-i-zer WD Hitch
camp-n-family
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
dadmomh
Pressure washers and travel trailers are worst enemies....suggest you don't even let them near each other.
Trailerless but still have the spirit
2013 Rockwood Ultra Lite 2604 - new family
2007 Rockwood ROO HTT - new family
2003 Ford F-150
4 doggies - We support Adopt/Rescue.
Sam, you were the best!
Cubbie, Foxy, Biscuit and Lily - all rescues!
2012Coleman
Don't use a pressure washer! The above suggestions are great, but I use a soft brush and clorox cleanup spray.
2018 RAM 3500 Big Horn CTD
Eddie_Griswold
My family and I just acquired a used HTT and when I cleaned the awning, I used a Mr Clean Magic Eraser for the stains that didn't come off with the soap and a brush. Worked like a champ; no more stains!
Edit: PackerBacker beat me to the punch
2004 Ford F250 Superduty Crew Cab XLT, 6.0L Diesel, Equal-i-zer WDH, Tekonsha Primus IQ Brake Controller
2012 Keystone Bullet Premier 31BHPR
Community Alumni
Not applicable
I use MrClean Magic Eraser for my awning, works great! :C
