โJul-14-2017 06:38 AM
โAug-14-2017 07:11 AM
Blazing Zippers wrote:
ib, Good to hear from you. Happy to know you're doing well.
You know---because of your reports, I bought a 6.4 Hemi and love it.
Thanks. See ya out there!!
โAug-13-2017 07:13 PM
โAug-13-2017 07:00 PM
Grit dog wrote:
Awesome country!
Hey looking at the axle pic, your spring question in the other thread, those Timbrens look too short. The other pic was loaded down, I can see now with the gap in the pic in this thread.
โAug-13-2017 06:56 PM
ib516 wrote:
Well, I spent the weekend wrenching on the truck. Here's what I got done:
- Installed a new ignition switch - it would stick in off position
- Installed 4 new shocks
- Oil flush and change oil and filter
- New air filter
- Chassis lube
- Rear diff fluid changed
- Front axle fluid level checked
- Trans fluid was new, but overfilled by about 2 quarts. I removed a trans cooler line and let the trans pump out 2.5 quarts, and rechecked, add to full mark after a test drive to warm the fluid.
- Installed ladder rack to haul kayak
- R+R all driver's side exhaust manifold bolts as one was broken, new gasket installed (PITA job)
- Removed transfer case skid plate and dumped 5 lbs of dried mud off of it
- New belts (2), idler (1) and tensioners (2)
- Couldn't check the T-case as the fill plug was seized in there. I rounded it off with a 12 pt 18mm socket :M...no leaks from the seals and no seeping for the infamous pump rub either, so should be OK
- Checked all tire pressures
- Checked all lights, one DRL is out, need to get one of those
- Checked 7 pin connector and used compressed air to clean it, then soaked it with WD40, then more compressed air (fully lubed my arm in the process :))
- Removed some junk from previous aftermarket stereo
Next is body work to remove the surface rust and I need to hit the wrecking yard and grab a spare tire and a battery hold down. That will have to wait until I get back though.
โAug-13-2017 04:36 PM
โAug-13-2017 11:03 AM
โAug-13-2017 09:40 AM
โAug-13-2017 09:35 AM
โJul-22-2017 03:06 PM
โJul-21-2017 10:43 PM
mike/kellie wrote:No No, mine is white, but was a reg cab, and I still have it, if fact I'm taking the RV back to the condo storage in the morning after using it for 2 1/2 months on the last trip. I will pick up the woundful Supercharged Chev. and use it to go to the cabin Sunday for another month or so.
Welcome back and glad to hear you're getting routines you loved into place. You're description of the truck sounds like it used to belong to "Supercharged", a character from AZ that might have trolled a little.
โJul-17-2017 01:09 PM
โJul-17-2017 08:12 AM
โJul-17-2017 08:11 AM
โJul-17-2017 08:07 AM
โJul-17-2017 07:45 AM
ktosv wrote:ib516 wrote:
Well, the other day, while browsing the local classifieds, I came upon a high mile 2006 Chev 1500, 4x4, 3.73, Ext. cab short bed. It's rough, but it was cheap. It had a 4.8L from the factory, but somebody swapped in a 5.3L. The chassis has 230,000 Km on it (~144,000 miles), and I have no idea how many miles the 5.3L has on it, but I was told it has less - around 100,000 miles. The truck has rubber floors, crank your own windows, but it has AC and cruise and a 4L60E auto.
Payload is 1245#, and it has the G80, locker in the rear, Z82 and Z85 towing and HD suspension options, and skid plates. I found the original window sticker in the glove box.
Welcome back to camping! You mention that it has the 3.73 axle. From what I know for the 2005/6 model years only the 3.42 and 4.10 axles were available for the 4x4. The 3.23 and 3.73 were available on the 2wd models. You mention you have the original window sticker, did you confirm it has the 3.73? I am wondering if the US trucks went this way but the Canadian trucks were still available with the 3.73?
Regardless, as long as you don't have the 3.23 axle that truck will do fine towing what you have. I even towed a 5000# GVWR hybrid with a 2005 Suburban with the 3.42 axle and I thought it did great.
Enjoy your upcoming trip!
