Back Porches, lets see em!
Slick_Rick
We're looking for a back porch on our Lance 865. I think I like wood better than diamond plate. 4' wide? Rails? Steps off the back? Does yours fold up for travel?
What makes it work for you? How much should I budget for a back porch?
Thanks
Rick
2015 F350 Lariat CC PSD 4x4 SRW
2015 Lance 865 Truck Camper
12 REPLIES 12
cleary
2006 F-350, 4X4, Crew Cab, V-10, Torqshift, Dually. 2008 Okanagan 106UDB. Both 4-wheelers and snowmobiles. KL7AY Our website
Slick_Rick
skipbee wrote:
We have one very similar to Ron Humphress, ours was made Jimmy Johnson, I'm not sure if he is still doing them. There is a firm, Justice Welding, that built our front cooler rack and could easily do a porch. They are located right at the Maryland/ Delaware line on Rt 113 North of Berlin, MD.
Thanks, some guys I hang with on AI said Justice does porches, I'll look em up.
So many AI guys on here, I knew I'd find some locals.
Thanks again,
Rick
skipbee
skipbee
2004 F350 Diesel CC SRW 19.5" Rickson W/T 4WD
2005 Lance 1121 well found.
See us on YouTube" Living the Lance Life" 3 of 4. Google skip bosley for TR's: Alaska, Assateague Island, Disney World & Fla Keys and a California Coastal jaunt.
JumboJet
gitpicker2009 wrote:
hey jumbo jet, that is exactly what I want to build, but I was thinking aluminum.
I really like the way you did that. How did you attach the steps? Welded or bolted?
Welded the hinges and can remove via pins. Same way I remove the porch from the TC but bolted hinges to bumper. Pull pins when I want to remove the porch.
gitpicker2009
noteven
Here is one that looks good if you pull a trailer:
Porch and steps
SugarHillCTD
Very basic. But it is attached to the truck and not the camper. I included it when I sold the TC. But before then I had added storage boxes to both sides.
I actually made it out of the front portion of an old motorcycle trailer with the main support being 2x2 square tube plugged into the hitch. To steady it from wiggling side to side I bolted 2- 1x1 angles at the right and left edges- these just slid under the bumper.
I just hit the untreated lumber with stain and preservative- no ground-contact needed. That saved weight.
John & Cathy
'12 Chevy 2500HD CC 4x4 sb
'16 Cougar 25RKS w/ Andersen rail mount
'13 Eagle Cap 850 (sold). B4 that a few other TCs and a TT
JumboJet
tkcas01
Oh, I thought the subject said Black Porsches.... Time to call the eye doc! :E
Roaming Full Timer
tonymull
Just built one! I used a hitch cargo carrier for the base. 4 feet wide, 2 deep and 18 inches high. All wood, not expensive and it holds my generator, cooking box, the screen tent, shower kit for the outside shower, gas for the genset, and other odds and ends that I don't want in the camper for whatever reason. The top is rubber mat. A couple of chains on the ends makes it very stable. Sorry don't have a pic, but I based it on one in the mod section. not too heavy for me to move myself when empty as it comes apart into 3 pieces. When I tow it comes out of the hitch and goes on the trailer. I have an 8'camper so the hitch is not obstructed.
AISURFFISH
Like that.. ??
Fold up... yes if needed but usually down.
$1000 new custom made..
That was on our old 05 881.. easily transfered over to the new 992.
BTW HOWDY NIEGHBOR!!
2017 F350 6.2L Crew Cab
Arctic Fox 990 2021 TORK-LIFT FAST GUNS AND SUPER HITCH
COOLER RACK OFF THE FRONT ALWAYS FULL OF FISHING RODS TICA TO BE EXACT
6pac
Look under truck campers university
Chevy 2006 2500HD 4 x 4 Duramax / Allison srw cc sb Fh air bags
Lance 2005 model 881 Max
Doriece & Ernest ( 6pac )
