Broke Truck
Road_Runners
My F250 6.0L psd engine shut off while we were on the road and wont start now. Anyone had this problem and what was the solution. We have plenty of fuel pressure.
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
13 REPLIES 13
bmanning
Road Runners wrote:
It turned out that the high pressure oil pump that feeds the high pressure oil to the injectors was bad. We were on the road pulling or fifth wheel far from home when this happened. We got it repaired and have since pulled our fifth wheel another 4000 miles over mountain and plain with no further problem. Our truck just turned to 91,000 miles.
Sounds like a decent outcome, all things considered; I'm sure the pump wasn't cheap but it could've been much worse.
Hope you get years & tens of thousands of miles of problem-free service from it.
BManning
baking in Phoenix :C
-2007 Volvo XC90 AWD V8
4.4L 311/325 V8 6sp Aisin loaded
6100lb GVW 5000lb tow
-1999 Land Cruiser
4.7L 230/320 V8 4sp A343 loaded
6860 GVW 6500lb tow
RV'less at the moment
Road_Runners
RollingRockTX
ib516 wrote:
I'm no expert, but I'll say ficm is bad.
X3,
Following.
2017 F150 Lariat 3.5EB
2016 Acura MDX SWD
2013 Yamaha Golf Cart
10 year old Quarter Horse, "Shadow"
2019 Jayco White Hawk 28BH
powderman426
ecoast wrote:
get yourself a $20 bluetooth obdII adapter (amazon or ebay), and download 'Torque' from the app store to your smart phone...
Read the codes.
Past.
Present.
Pending.
no guessing.
X2
Or a tablet.
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
ecoast
Read the codes.
Past.
Present.
Pending.
no guessing.
07 5.9 CTD & 2000 Northstar Laredo TC towing 87 Samurai ORV on dual axle trailer
45Ricochet
carringb wrote:
There are a number of issues that can cause that.... Bad FICM, high-pressure oil leak, bad HPOP, debris in the injectors due to an oil sump screen, broken wire in the engine harness, bad ICP sensor or solenoid, faulty oil pump...
You need to just go a dealer, or an independent shop with the proper 6.0 diagnostic equipment. If the shop starts suggesting swapping parts, tow it somewhere else. When the diagnostics is done the bad part is identified, be sure to ask about the cost of repairing any consequential damage (for example, a bad FICM can damage all of the injectors, which cost over $3,000 for the set) so you can decide up front if its worth fixing.
X2
Especially the last sentence. How many miles do you have on it?
Best of luck
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
rhagfo
As stated in many post could be many things, if it turns out to be minor great. If it is a major issue, this may be as cost efferent as a 6.0 crate.
Destroked
๐Ÿ™‚
6_7_tow_rig
My dads 06 did that too. He had to coast to the side of the road and it wouldn't ever restart. Had it towed and they replaced the EGR valve. Modern vehicles are all so complicated though unfortunately it could be a million different things. Good luck
2018 Dodge Ram 2500 Laramie Cummins 4x4
2013 Primetime Lacrosse 318bhs
BB_TX
My '07 F350 6.0 suddenly shut down while towing the 5er on an interstate near OK City after having been running fine for about 3 hours. Engine would turn over strong, but would not restart. Had about 54,000 miles on it. Had it towed to Ford dealer. It was the cam sensor. Replaced under warranty. No other problems before or after that event.
carringb
2014 ORV really big trailer
2015 Ford Focus ST
rhagfo
Look at the voltage on the FICM (Fuel Injection Control Module) If that is good. Look to batteries and alternator.
Look here for more help.
Powerstroke forum
ib516
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
donn0128
Different truck.
Sorry for the snide comeback. But there have been so many reported issues with that motor it is any bodies guess how bad it is. Bad fuel, bad computer, head gasket blown.
The only way to know for sure is to have it towed to a Ford garage with a good diesel mechanic and let him have a go at it. While your at it, you might look at new trucks.
