DEF Crystalization Concerns
krazymatt
So I have a 2014 Ram CTD with DEF. So far it has 8k miles of trouble free service and I really love the truck. I am concerned regarding the crytalization of the DEF. I've noticed in the filler neck you can sometimes see crystallization residue as well as when you look at the empty bottle a day later the remnants turn to crystals. Is this going to pose a problem in the future? I use the Peak Blue DEF commonly available. Thanks....
New Mexico
2018 Ram 3500 Dually Cummins 4x4
11 REPLIES 11
krazymatt
Hiking Hunter wrote:
Krazy -
Like the others have said, crystallized spillage not a problem.
I have >20k miles on my 2013 now and have always filled the DEF from bulk at truck stops without any problems. You may want to consider that - much less expensive. The last time I filled up the DEF it was $2.69/ gal.
I know about that bud, but I live in New Mexico which is the sticks-LOL. The nearest truckstop to me is 100 miles. I was on the road last weekend and pulled up to the DEF pump in Oklahoma at a truck stop and the damn card reader wasn't working so I ended up picking up a 2.5 gallon jug at wally world on my way back.
New Mexico
Hiking_Hunter
Krazy -
Amateur Radio WA4GIY
2015 Montana High Country 305RL
2013 RAM 3500 4x4, crew cab, long bed, 6.7 CTD, Aisin trans.
CGVW 20460 Lbs.
N-Trouble
Keep it simple and just dump the entire 2.5gal jug in. Refilling A gallon at a time is overkill and not needed.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
krazymatt
Thanks again guys. I'll definitely maintain it at half tank during summer. Maybe just buy a gallon at a time. Lately I've been hauling 1000 mile trips so it's been using some.
New Mexico
TXiceman
ramgunner wrote:
That's normal. It's 32.5% urea, the rest is deionized water. When it evaporates you will see the crystals.
Wash it off of anything that it spills on, but the stuff at the end of the filler opening is normal.
Not a worry.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
Randu
N-Trouble wrote:
Any DEF that is in contact with air will quickly crystalize. It's not so much a problem once the DEF is in the tank. The life expectancy of DEF however is very dependent on temperature. The warmer it is the more quickly it goes bad. In summer months I typically only add on 2.5gal jug when it gets low. This puts fresh DEF into the system every few months.
Same with me. Randu
2017 Chevy 3500HD SRW Crew LTZ
4x4,Duramax, Allison.
2017 Jayco North Point 381DLQS
Previous: 2000 Travel Supreme
2005 Newmar Kountry Star
2008 Mobile Suites 36TK3
N-Trouble
krazymatt
Ok thanks!
New Mexico
agesilaus
It's just where some had the water evaporate, won't happen inside the truck.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
ramgunner
Editor - http://www.RamGunner.com / http://www.MomentumGunner.com
2014 Ram 3500 Tradesman/CTD/AISIN/4.10/4WD/CC/LB/DRW/VHF/UHF/APRS/CB/SCANNER
Grand Design Momentum 385TH (Polaris RZR800/VHF/UHF/HF)
RedRocket204
Not sure what kind of problem you are concerned about... just rinse it off with water if you see the crystallization or if you spill any.
Honestly, you could probably just leave it and nothing will happen... but directions do tell you to rinse it off if you ever spill it.
I've seen the crystals near the filler location on mine and no problems to speak of after 4 years. I'm getting the feeling the warnings on DEF are to avoid frivolous lawsuits.
I love me some land yachting
