Diesel mpg
Racine96
Question: those of you who use a diesel truck to pull an RV, what kind mpg do you get when you pull your RV?
45 REPLIES 45
naturist
I have a small diesel TV, a Jeep Liberty CRD. Don't laugh, those of you with Great Big Honkin' A** Trucks, but it has a 2.8 liter 4 cylinder common rail engine.
I pull a small TT, a 21 foot Coachman that weighs around 3600 lbs empty, and "full" is usually in the 4500 lbs range. Worst mileage I've ever gotten was 9 mpg pulling into a 50 mph headwind in Oklahoma. Best has been 16, with my average just over 14. It must be noted that most of the fuel this rig uses is because of the wind resistance of dragging an 8x8 foot wall around. I used that TV to take a car on a dolly 400 miles a couple years ago -- very nearly the same weight as the TT, but MUCH more aerodynamic, and got almost 19 mpg.
sclark
2013 Ram 3500 pulling rig in sig. 11300 lb 5th wheel. 12.7 at 60 mph. 20 empty at 60. A bit better at 62 mph. Aisin transmission.
2013 Ram 3500 Crew Cab Cummins Aisin transmission
2014 KZ 358BHK
Honda eu3000is Generator
PA12DRVR
Based on on-board computer (not what it took at the pump):
2006 F350 with 6.0 engine and 4.30 gear ratio, towing 38' KZ Escalade (circa 16,000#'s): Highway towing at 65: 9.9 - 10.2 mpg.
Without the trailer, it jumped all the way up to 13 mpg!
CRL
My RV is a 1946 PA-12
Back in the GWN
noteven
06 5.9 Cummins, 6spd manual.
15000lbs 3 axle 5th wheel trailer x 13ft high x 39ft long
10 - 12 mpg US
Will happily do 8-9 mph in wind.
0 mpg idling.
biggrigg
00 Excursion PS with 30' trailer. Usually about 12 mpg. Sometimes 11 mpg.
2011 Sabre 30BHDS
00 Excursion 7.3 PSD
rgolding
Just back from a Fall Florida trip and averaged 11.4 mpg, traveling 60 to 65 mph pulling a Artic Fox 30U with a 2009 Duramax and Allison transmission. Very pleased with the equipment.
Smooth Sailing,
Ric and Jan
Southern Illinois
2016 Jayco Seneca 37FS "Low Key"
APT
My friend pulled my TT with his 2012 Silverado dually and got about 12mpg @ 72mph. Compare that with 8-9mpg @ 65-70mph for my 6.0L gasser.
2017 Subaru Outback 3.6R
2-MTnesters
04.5 Duramax LLY all stock, Pulling a 38' 15,000# 5er, 9-10 mpg.
The Webers
Me- Tim
DW- Dea
Pooch- JoJo boxer/lab mix
2010 Keystone Montana 3400RL Hickory Edition "The Taj Mahaul II"
2004.5 GMC Siera 2500HD SLT CC 4x4,6.6 Duramax/Allison, 3:73 gears, Firestone air bags, Reese 16K slider, TFI 45 gal fuel tank, Rhino Liner
Old-Biscuit
8000# truck.........14,000# 5th wheel (13'3" wind sail)
4 speed auto.....4:10 rear end (5.9L CTD)
10.5-11.5 mpg 62mph
goducks10
2012 Ram 2500 CTD pulling a 9000lb 5'er. 10.5-11.9 depending on flats or mtns.
clubhouse
Stock '07 LMM Duramax pulling ~6200 lbs 30' TT 12mpg. I generally dive 60-65
N6761U
99 PSD pulling 12000# 5th and get between 9 and 12
scottykrug
09 dodge ram 3500 6.7 ctd pulling 24' gulfstream @ 5500-6000# 13-15mpg with cruise locked at 65mph
2009 Ram 3500 Mega 6.7TD
2015 Puma Palomino 295BHSS
Copilot (DW) Navigator (DD) Flight Engineer (DS)
Wills6_4_Hemi
08 6.4 psd 62 mph 14.2 towing 8500lb TT and golfcart in bed. 18.6 empty.but my trucks not stock.
ktmrfs
35' outback TT 18K combined weight. Duramax CC 4x4 10.5-12.5mpg @ 60ish.
towing a 7x14' cargo trailer, 12K combined lower profile. add 1.0-1.5mpg to the above
2011 Keystone Outback 295RE
