Do NOT touch anything inside the cap...or even blowing it clean with
your mouth...all it takes is that one tiny drop...
Do NOT hose off, pressure wash, etc around the dist, wires and plugs
Replace the wires with spiral wound SS *WIRE* that has an inductive
core that the wire is wound around. One of your leads could have gone
bad, going bad or been pulled to frey/break the carbon filled fiber
glass 'wire' conductor.
Use spark plug grease on both the cap and spark plugs
DO NOT do this while your hands are dirty. A finger print can become
the carbon track after one flash over
Check your coil...it maybe over voltage and/or have you gone to an
after market coil and/or system? When I had kit capacitor ignitions...some
times it would do this if everything was NOT perfect
Consider modifying your spark-plugs to have less resistance to the
jump over on the center to ground...or more correctly...takes less
voltage to jump employing the corona effect
My 8.1 is at 100,000. Time for plugsCutBacksparkplug cutback
You can buy'm and only a few spark plug OEMs sells cut back spark plugs
NGK is my fav and they hand build these for racers & serious boy racers
$200 bucks EACH
![](http://www.jscspeed.com/images/products/thumbs/c342b606f572bbbd.jpg)
Or you can make your own and is what I do for *ALL* my engines and
the whole HOW2 in the link above
![](http://img.photobucket.com/albums/v77/bentoy/EngineTranny%20AUTO/NGK7forSubcloseup.jpg)
cutbackplug cutback
PS...I'm not a fan of platinum plugs...they are just good enough
and are mainly for that 100,000 mile change interval...
-Ben
Picture of my rig1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
