F150 payload quetion
HaveAGoodOne
I am looking at a new f150 crew cab 4x4 and it looks like the best payload I can get with those options is just under 1500 pounds. Am I reading the towing guide incorrectly? I know I can get up to 2500 with a regar cab 4x2.
28 REPLIES 28
Buck50HD
Most of the standard 4x4 crew trucks are around 1500 lb, the max tows are 1800 while the HD payload are 2200+. I have not driven a max tow but the HD payload package is a huge jump in stability. It's not even comparable. Mine has 2171 on the sticker, crew 4x4 with HD payload and max tow.
New: 2014 F250 Lariat 6.2 Crew 4x4 3.73 156", 2725 lb payload
Old: 2012 F150 XLT ECO Screw 157" 4x4 3.73LS Max Tow HD Payload, 2171 lb payload
2013 Heartland Sundance XLT 285BH (7750/8800lb, 1400/1700pin, dry/loaded)
belairbrian
BamaFlum wrote:
How does 4x4 vs 4x2 affect payload?
payload is GVWR less curb weight.
Since teh GVWR is going to be the same (or very close) the extra weight of 4x4 gear comes off the payload.
Think of it this way. Take a 4x2 truck with a 2500 lb payload. Load an extra differential and transfer case in the bed. How much payload is left. In the OPs question 2 extra doors and a bench seat got thrown in there as well (reg vs crew cab). Keep doing this until all the extra parts are in the bed. The curb weight as gone up but not the GVWR so the difference (payload) is less.
TV 2007 Chevy 2500 Long Box Vortec 8.1/Allison or 2016 Tundra Crew Max 5.7L 4x4
2022 Freedom Express 192RBS
Equalizer 4 way WDH, Prodigy 3 BC
USAF Retired
WAR EAGLE
APT
I test drove two 2011 F150 Crew cab 5.5' bed 4WD Lariats both with max trailer towing package. 1750-1850 pounds of payload per the driver's door. The Max trailer tow package offers a little higher payload for the 5.5' bed over 6.5' bed. But there is the HD payload package only available on 6.5' bed trucks which bumps up to about 2100 pounds of payload for very well equipped crew cab 4WD F-150s. You'll probably have to custom order a truck with either packages.
Ford bumps GVWR on 4WD trucks, so payloads are similar for the same equipment.
2017 Subaru Outback 3.6R
bigcitypopo
Transfer case weight and gearing... No? Maybe a different spring setup?
2014 RAM 2500 BigHorn CrewCab 4x2 ShortBox, 6.7L CTD
2014 Keystone Springdale 294bhssrwe - Hensley Arrow!
The best wife, 2 kids and a bunch of fun
BamaFlum
skipnchar
With a regular cab long bed with the HD option the payload is 3,050 lb. For a Super Cab with the HD option it's 2,650
For a Crew cab with the Hd option it is (something like) 2250 lb. but I don't have the exact number. The key is to order the HD payload option.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
HaveAGoodOne
Ok after your replies I found the ford f150 payload selector on fords site. I did see an crew cab 4x4 f150 there with gvwr of 8200 and payload of 2300 pounds. That's the one I was looking for. Thanks.
301TBS
My 09 scab 4x4 xlt has 1426lbs. I added hitch, cap, and running boards. It sure goes down fast! As said, less options gives you more.
2019 Springdale 240BH
2009 F150 Scab 4x4, 4.6, 3v. 6spd. 3.73/9.75
Reese dual cam
Shadow_Grey
My Max Tow has between 1800 and 1900 lbs. Order it right and spare the options/packages you don't really "NEED".
HD option has even more...2100-2200 lbs payload.
'11 F150 XLT Red Candy Met. Ecoboost 4X4 Screw 5.5', Max Tow,Reese R16k 5th wheel hitch,Ride-Rite Air Springs, E Rated Tires, Extang Cover
'13 Keystone Cougar X-Lite 29RES,triple slides,Mor/Ryde suspension, Reese 5th Airborne Sidewinder, 16" E rated tires
TomG2
"Most" F-150's are in that range although "Most" forum members have much higher numbers.
HaveAGoodOne
Looking at the towing guide 1500 is the cargo rating with 8200 gvwr with the payload package. Maybe I am reading it wrong.
MFL
Nomad II
Nomad II
Just looked at my neighbors 150 CC 4x4 6.5 bed, with Max trailer tow. The sticker on the door showed 1531 payload. It is a 2012 with 3.5 eco.
Merrykalia
In order to up it, you have to go with the HD package and Max Tow Package.
2017 Ford F350 Crew Cab 6.7L 4x4 DRW
belairbrian
probably not too far off. Betting both have similar if not the same GVWR. Starting with the payload for the regular cab 4x2 you subtract the weight added by the crew cab, doors seats, etc. Then subtract the weight of the extra differential for the front, transfer case, extra cross members, drive shaft and such.
USAF Retired
WAR EAGLE
