โApr-24-2016 08:09 PM
โApr-25-2016 10:00 PM
โApr-25-2016 09:24 PM
โApr-25-2016 01:21 PM
โApr-25-2016 11:34 AM
โApr-25-2016 11:15 AM
โApr-25-2016 10:42 AM
mkirsch wrote:
There's no point in wasting time with a shop until it won't move anymore. All a shop is going to do is put the truck up on a rack, LOOK (visually) at the transmission, say "Yup, it's a transmission. Looks fine," and charge you a few hundred dollars for the privilege.
If nothing is sticking through the case, there's nothing a transmission shop can "look" at without pulling the transmission and tearing it down. You're not going to want to spend that kind of money and not rebuild the transmission, which means even more money...
Flush and fill with a new filter might be prudent as the mileage is still low enough that flushing and filling may still do more good than harm. Other than that, run it until you see a pile of parts and/or a puddle emerge from under the truck.
โApr-25-2016 10:39 AM
โApr-25-2016 10:29 AM
โApr-25-2016 10:20 AM
Kayteg1 wrote:
2001 is 4-speed?
Those transmissions are computer-controlled and should shift smoothly.
One of Ford Truck forums should have plenty answers to your question.
โApr-25-2016 08:46 AM
โApr-25-2016 05:33 AM
โApr-24-2016 08:52 PM
โApr-24-2016 08:41 PM
