โAug-27-2017 06:43 PM
โAug-31-2017 06:31 AM
SweetLou wrote:rjxj wrote:
Carry 5 gallons extra and run it empty to see how far it goes
I am sorry but that is some really poor advice. You should never run a tank of diesel out and for many reasons. A couple that come to mind is the sludge you have at the bottom of the tank just got sucked into your very expensive injectors, and second you may have to prime a restart.
โAug-31-2017 05:04 AM
โAug-30-2017 02:01 PM
drsteve wrote:
True. Running low also allows the pump to suck up any sediment that may be in the tank.
โAug-29-2017 11:49 AM
Flashman wrote:
My fuel light came on in my new Ram 3500. I was near a diesel station so I filled it up - could only get 25 gallons in! It is a 31 gallon tank. Does this mean I have a 6 gallon reserve after the fuel light comes on?
โAug-29-2017 10:00 AM
โAug-29-2017 09:49 AM
rottidawg wrote:
I seem to recall a warning about running your tank too low very often. With the fuel pump inside the tank it depends upon a certain amount of gas for cooling?
โAug-29-2017 09:28 AM
โAug-28-2017 10:35 AM
โAug-28-2017 07:30 AM
โAug-28-2017 05:29 AM
โAug-28-2017 04:59 AM
โAug-28-2017 04:27 AM
โAug-27-2017 08:25 PM
4x4ord wrote:
When I'm towing a heavy load I can ignore the fuel gauge. I have to fill up at every freaking service station I come to.
โAug-27-2017 08:05 PM
