GM 6.0 gear searching.....
ericpatt
Help??
While this may have been covered to some extent on this forum or another, I'm looking for suggestions for my 2012 Suburban 2500 with the 6.0l engine.
Towing my boat(04 Nautique) it's awesome. Hardly know the boat is there.
However, when hauling our 30ft camper it's a different story. Camper weighs 6900lbs empty. Fully loaded it's probably close to 8000 not including wife, 3 kids, dog and misc stuff in the truck. Can't keep it 60-65 without it searching for a gear it "likes". I usually downshift manually but tach is constantly at 3k.
What to do? Love the truck. Kids are happy in back and plenty of space. Called a couple shops.
1 suggestion was to modify computer?
2 suggested cold air intake, tuner, & exhaust?
Does any of it work??
There's got to be something I can do. Slowing down only makes me feel like a traffic hazzard. Would like to be able to pull at least 65mph on the highway....
40 REPLIES 40
allen8106
I had a 2009 GMC 2500 with a 6.0 in it. I used manual shift and kept it in 5th gear and ran at highway speeds of 65 consistently without any issues. You are doing more harm by running it in automatic mode pulling that heavy of a load.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
mkirsch
Nomad II
Nomad II
One question I did not see asked:
Stock tires? If you're running oversize tires they have the effect of soaking up power and effectively raising your axle ratio (lower numerically).
intheburbs
BurbMan wrote:
Intheburbs, the caption on your pic should be "Last pic I took before the trans blew."
Well, the first time I had the trans approaching 240° was our trip to the Grand Canyon/Utah/Colorado, and that was 4 years and 50,000 miles ago. Still the original transmission, still shifts perfectly.
My motto is, "Know your equipment." A close friend of mine is a transmission validation engineer at GM. He spends most of his time at the Milford proving grounds, has his license for driving there, and gets to do some pretty cool stuff with some great cars and trucks. His first job/project at GM was validating the 6L80/6L90 transmissions. I asked him about my plans and the temperatures I was seeing, and he assured me they did much worse in validation.
Granted, my experience is a data point of exactly one, but most of the components on the 2500 Burb, as you probably already know, are total overkill for the application.
And, unlike your '01 that uses Dex 3, the Dex 6 in the GMT900 trucks is a substantial improvement and can take some serious heat. The "trans hot, idle engine" warning only comes on at 265°. I also change out the fluid religiously.
2008 Suburban 2500 3LT 3.73 4X4 "The Beast"
2013 Springdale 303BHS, 8620 lbs
2009 GMC Sierra 1500 Denali (backup TV, hot rod)
2016 Jeep JKU Sahara in Tank, 3.23 (hers)
2010 Jeep JKU Sahara in Mango Tango PC, 3.73 (his)
LIKE2BUILD
ericpatt wrote:
Thanks everyone! The trip went well. Madison, WI - Bowling Green, KY. Tow/haul shifted to manual and limited trans to 5th gear. Highest trans temps got was about 165-170. On several flat stretches I was able to get it to hold 73-4mph in 5th gear around 2500rpm. Was happy with that.
Otherwise, it was holding 3-3300rpm to keep 65-70 through rolling hills..
That is right where that engine lives quite happily and makes it's best power. I spent 10 years towing with a Chevy 2500HD 6.0L with 4.10 gears and the 4L80E transmission. It towed my TT pretty well but always downshifted on hills.
I found in eastern Kentucky that it didn't go much of anywhere under 3,000 RPM. However, once you hit the magic number of 3200RPM...up up and away!! :E I looked up torque curves a long time ago and seem to recall that 3200 - 4200 is the real meat of the of the curve on this engine. You'll pull up a hill just fine if you keep the engine in this range.
KJ
'14 Ram 2500|Crew Cab Long Bed|4X4|Cummins
Curt Q20 with Ram 5th Wheel Prep
2000 Crownline 205BR
1997 Ranger Comanche 461VS
'01 Polaris Virage TX PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (21, 15, & 13)
1 forgiving wife!!!
BurbMan
Hi Eric, glad the trip went well! I agree with most here, don't waste time on intake/exhaust, if you want more power then do an axle gear change from 3.73 to 4.10 (no 4.30 on GM, next stop would be 4.56 and that's too tall for what you're doing). Both axles will cost around $1500 to do at a good axle shop.
Aside from that, it sounds like you stopped the hunting by limiting the trans to 5th gear. One of the ways that the mfrs maximize fuel economy is to program the ECM to upshift at every opportunity, and it can be frustrating on rolling hills. The wind is also a factor when towing a big hard-sided trailer. As soon as the load on the motor abates a little, the trans will try to upshift if you let it, but if you need power again in 5 seconds, it will downshift to deliver.
FYI, your trans temps are right where they should be, I have never seen higher than 205 even going up a steep incline. The factory cooler on the HD trucks has been moire than sufficient in my experience, it's mainly the 1500 series trucks that benefit from more trans cooling.
dodge_guy
4.10`s or if 4.30`s are available will allow you to use 5th gear. and will gain you .5 mpg because the engine will no be working as hard!
I went from 3.73 to 4.30 and it was the best thing I did. I could never use O/D. I can now cruise in O/D at 70 at 2700rpm as opposed to 3200 in 3rd at 67! (it used to hunt for O/D at 65-67) granted I have a 4 speed, but the idea is the same!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
lawrosa
PAThwacker wrote:
lawrosa wrote:
goducks10 wrote:
Change your rear end gears.
Dude he has a 6.0 and 3;73's... Its bad enough he gets 2 mpg...
Dont change rear gears... Just ride in 4th gear with that load as I stated above in my post...Use tow haul mode!!! Its that little button on the shifter handle..
I guess no one read my post and just reply for the heck of it..
2500 burbs with 6.0 all had 3;73 AFAIK.. and can tow 9000 plus...
What 2500 6.0 3.73 tows 9000lb?
My 04 is rated to 7600lbs. 07 on up can’t handle tongue weights of 7600lb trailers.
He has a 2012.....
Chevy Suburban, GMC Yukon XL 2500
2500 Long Wheelbase 2WD 6.0L V-8 9,600
2500 Long Wheelbase 4WD 6.0L V-8 9,400
https://dcd96xmek71bc.cloudfront.net/trailerlife.com/2012_towing_guide_lo_res.pdf
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
PAThwacker
2015 Keystone Springdale Summerland 257rl
Tow vehicle: 2003 GMC K1500 ext lb
Previous: 14 years of 3 popups and a hybrid tt
deltabravo
Iraqvet05 wrote:
Cold are intakes in my experience are a waste of money.
Ditto.... and why they are called "Cold Air Intakes" is a mystery, because most of them don't draw in cold air from outside the engine bay. Most of them consist of a big cone shaped filter with a metal shield around it, with no sourcing of air from outside the engine bay.
On my 09 Duramax (same body style as the OP's SUB), the factory intake draws in air from outside the engine bay, which is the case with many other GM trucks as well.
ksss
goducks10 wrote:
All GM 2500 trucks now come with 4.10 standard. Must be a reason.
I had a 2011 2500 HD CC with the 6.0 and 3:73. I traded it in on a 2015 3500 CC with 4.10 and it was much better. With a size larger tires than OEM I got 13-14 mpg not towing and down to 5-6 at 30K combined. If you are really working the suburban your actual towing mileage my go from not changing to perhaps improving slightly with the 4:10's. I think it is the best bang for the buck improvement you can make for what you use the SUV for. You might see a 1 mpg reduction in hwy nontowing mpg. The 4:10's are a much better match for the 6.0 than is the 3:73 if you towing with it. Love that motor.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
parker_rowe
Sounds good!
2015 Starcraft TravelStar 239TBS 6500 GVWR
1997 GMC Suburban K2500 7.4 Vortec/4.10
1977 Kawasaki KZ1000
ericpatt
allen8106
You can tow at 65 but you'll have to do it in a lower gear and at higher RPM. I had an 09 GMC 2500 HD with a 6.0l gas engine. We couldn't tow in overdrive (6th gear) had to leave the transmission in manual and tow in 5th gear in order to get the revs up into the proper power band for towing the 5ver. Oh....and one other thing, you absolutely cannot tow with the cruise control on. Ours down shifted every 10 miles between Wichita and Holbrook, AZ. That's why I went to diesel.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
parker_rowe
APT wrote:
Good explanation, parker.rowe. While I understand the math well, my point is that 10-15% more wheel torque may not be enough for OP's exact situation, and even less likely worth $2-3k. 5th gear to 4th gear ratio is 0.85->1.15, plus the 500rpm jump closer to peak torque of the 6.0L. That's free, a button click M5->M4.
I'm with intheburbs. Let it rip. The powertrain is 2500HD designed for far more abuse than recreational RV towing.
I agree. That 6.0 will turn 3k or more all day long, and that was the OP's original question.
Just watch your temps and let'er eat!
