Grey Water Tank isn't draining....
JWWPHOTO
I am sure I have a grease plug in the small bore drain that comes off tank and ties into the 3" from Black Water tank.
What is the best method you have found to get it flowing again?
Jeff W Waldrop
17 REPLIES 17
JWWPHOTO
Thanks Northshore.
Jeff Waldrop
_1nobby
northshore wrote:
we found that when they cut the holes in the tank they left the plug in the tank and it floated in the tank and obstructed the flow when draining.
Of course they did.....thank GOD they aren't building airplanes.
northshore
On a wild guess, our wild cat had trouble draining the black tank, after many problems and frustration, we found that when they cut the holes in the tank they left the plug in the tank and it floated in the tank and obstructed the flow when draining.
Just something to check
JWWPHOTO
Thanks, guys. a lot of great ideas. I think I have an attack plan.
As far as the grease, the camper is 8 years old and my wife isn't real good at eliminating grease or food particles before rinsing down the drain. I think the slide seems to working but that is possible too.
Thanks, again for the great advice.
Jeff W Waldrop
bobndot
fla-gypsy wrote:
Old-Biscuit wrote:
Drain valve is not opening.........handle might be moving but valve slide is still closed
X2
x3. part 2, in my post. That is what i was talking about. Thats what i would check before i stated poking holes etc.
fla-gypsy
X2
Old-Biscuit
sky_free
I've heard that dissolving a box of baking soda into a gallon of hot water, pouring it down the sink, and leaving it overnight can help. It's cheap and worth a try at least.
2017 Escape 17B, 2012 VW Touareg
SoundGuy
hohenwald48 wrote:
Just wondering how you would get a "grease" plug in a 1.25" drain line? That's a lot of grease. I think I might look for some other cause.
Agree, hard to believe any grey water tank system could be totally plugged from any content. :h Nonetheless, you might try some Walex Elemonate and/or Walex Commando in your tank to see if that helps relieve the tank's "constipation". :W
2012 Silverado 1500 Crew Cab
colliehauler
Do you know the tank is full or are you going by the gauge?
hohenwald48
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
schlep1967
D.E.Bishop wrote:
Here's an easy way, buy a Hydroflush by Valterra or similar 3" fitting, attach you three in hose and connect to dump inlet. Open the flush valve and run a plumbers snake or flexible wand up through the water hose fitting to the blockage. You can also attach a water hose to the Hydroflush fitting and turn on the water.
Good luck and let us know what you did and did it solve the problem.
This^^ with the option of hooking a hose up to your outside shower connection and flushing with hot water to melt the grease.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
D_E_Bishop
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
bobndot
1. I would do this at a dump station.
2. It is also possible for the gate on the valve to be jammed or broken
3. If it is a blockage and the valve is working (sliding) ,
I would use an old/cheap sewer hose and poke a small hole in it close the valve where you could install a snake. This way the contents will flow thru the hose into the septic system and not all over you or the friend you really don't like, who you asked to do this for you. ๐Ÿ˜‰
