Apr-18-2018 05:40 AM
Apr-20-2018 12:06 PM
Apr-20-2018 10:36 AM
Part of that is that 4x4 are heavier in the front than comparable 2x4 and so the 2wd has more weight distribution on the rear than the same 4x4 truck in 2wd .
Apr-20-2018 10:01 AM
jaycocreek wrote:Part of that is that 4x4 are heavier in the front than comparable 2x4 and so the 2wd has more weight distribution on the rear than the same 4x4 truck in 2wd .A empty 2wd DRW needs all the help it can get under those circumstances.
I keep hearing that over and over on the internet so I did a test this last winter with my empty 2WD dually and my sons 2500 HD 4X4 in 2WD..Solid snow floor with 10" of fresh snow on top..The 2WD dually did quite a bit better in 2WD than the Chevy 4X4 in 2WD...Mine had siped Cooper AT-3's and his had siped Toyo's..
I have had the same experiences on work duallies with stock standard tires in the mountains for work/snow/ice and mud.They did just as good or better than the 4X4's in 2WD.
We must have special mud/snow and ice in Idaho.(laughing)
Apr-20-2018 08:23 AM
Grit dog wrote:
^Key being siped.
Makes a huge difference and most are not familiar with it.
Apr-20-2018 08:22 AM
JIMNLIN wrote:
IMO you won't like the solid rib tire like the XPS Rib or better yet cost wise the Bridgestone R-250 as it has no tread lugs for traction in green grass or a muddy campsite or winter driving on snow pack or slush. A empty 2wd DRW needs all the help it can get under those circumstances.
The Cooper HT-3 or similar tread would be a perfect choice with its two solid outside ribs and a all season type tread in the center for a bit of traction. Cooper recommends this tire for commercial service.
Apr-20-2018 07:55 AM
Apr-20-2018 07:39 AM
Apr-20-2018 06:33 AM
I want tires with solid outer tread bar to help eliminate feathering. I want quiet and most of all I want them to last a long time.
when its time, I may look into the cooper discoverer HT3 (50K mile tread wear warranty)
But my new truck is 2wd, dually with cast/polished wheels that I can't rotate. fronts always wear faster, so I think once its time for front tires, I will buy 4 for the rear than I have 2 pair to install on front as time goes by
Apr-19-2018 09:50 AM
Apr-18-2018 09:56 PM
Apr-18-2018 09:15 PM
Apr-18-2018 10:19 AM
Apr-18-2018 08:22 AM
Apr-18-2018 07:48 AM
deltabravo wrote:
Michelin XPS Rib
