How to rotate dually tires
bobbolotune
The manual for my 2016 Ram 3500 dually shows tire rotation only side to side. Specifically, switch the driver front and the passenger front tires, switch the outer rear tires driver to passenger, and switch the inner rear tires driver to passenger. The picture showing how to rotate shows no rotation back to front.
The manual really doesn’t explain why not to rotate back to front. It does say the rear tires must be matched for wear. Possibly the concern is that if tires are moved back to front that wear won’t match.
The manual does explain why it says to keep the inner rear wheels inner and outer rear wheels outer. It is for the Tire Pressure Information System. To quote, “The Tire Pressure Information System uses unique sensors in the inner rear wheels to help identify them from the outer rear wheels, because of this, the inner and outer wheel locations cannot be switched”.
With my last tires it turned out that I had an alignment problem (now fixed) that I wasn’t aware of until I noticed that the tires were wearing unevenly. Since I was rotating the front tires only side to side both front tires wore unevenly on the outer edges. By the time I noticed this the tires were unsafe and I had to replace the tires probably 6,000 or 8,000 miles early.
I had to have the tires replaced during a trip. I ended up at a tire shop in a rural area that seemed to have plenty of experience with duallys. He told me to ignore the manual. He said that they rotate back to front all the time. He says they take the best looking tires from the back and put them on the front.
If I had rotated like that it would have stalled the uneven wear that killed my last tires.
I am about to get the new tires rotated for the first time. I have been telling the mechanic to follow the manual. I am now totally unclear what to do. It would seem that only rotating side to side in the same positions really isn’t going to help much because every other rotation the tires end up back in the same location.
It could be what the manual says that if you don’t keep the inner tires inner and outer tires outer it will confuse the Tire Pressure Information System. But really how important is that? It is nice to have the tire pressures in the instrument cluster because I look at the pressures frequently as I drive, much more often than I would find myself checking tire pressure manually. But I don’t care much about location. If a tire is low (something that actually has never happened yet) I can find out which one by checking the tires manually.
Does anyone know the correct answer to this question? A set of dually tires is expensive so I want to take care of the new tires.
Lance 850 truck camper
2016 Ram 3500 regular cab long bed 4x4 DRW 6.4L HEMI gas
44 REPLIES 44
JimK-NY
I stopped doing routine tire rotations decades ago. I have not had any issues with premature or irregular tire wear. If there is a problem with the suspension, then rotations might just cover it up. Instead get the alignment or other issue fixed.
The idea of routine tire rotations should die along with the 3000 mile oil change.
mkirsch
Nomad II
Nomad II
ticki2 wrote:
First thing I would do is try the X rotation as your tire guy said and see what happens with the TPMS . If in fact it screws up the display , shame on Ram . To not be able to move an inner rear except side to side is crazy. If it was me I would sacrifice the TPMS in favor of proper rotation and better tire wear . In 65 years of driving I have had 0 blowouts and only a handful of flats , knock on wood . A blowout is instantaneous so it doesn’t seem TPMS is going to be too helpful . Just my 2 cents
Blowouts are not instantaneous. They will be preceded by a rise in temperature, and a corresponding rise in pressure. The TPMS should warn you of a tire getting hot so you can get pulled over before it blows.
mkirsch
Nomad II
Nomad II
THIS is why they do not show rotating tires front to rear.
Since you can't rotate the inners to the front, you wouldn't want to rotate the outers to the front either, because the inner tires never get any front wear.
JRscooby
I always replace the tire on 1 axle as needed. Maybe if I had all wheel drive I would be sure they all matched to protect differentials. 4X4, only engaged with poor traction, not as much of issue. The axles do different jobs, so it stands to reason tires will wear at different rates. Often on my vehicles, tires don't match front/rear.
One thing to watch when moving a steering tire to dual; If the tires you mount side by each are just a little different in height the short one will not last any time. And as it wears, it will wear at a ever faster rate.
Tvov
bobbolotune wrote:
The guy at the tire place told me that I needed to replace all 6 tires even though it was only the front tires showing wear. He said that on a dually you need to replace all tires at once. I told this to someone in a campground who said it is completely untrue. Maybe there is concern about matching the 4 rear tires, but he said the front tires can be replaced independent of the back tires.
So maybe follow the manual and if the front tires wear out sooner I can replace only the front tires. Opinions?
That is what I did with my dually. The rear tires will last a LOT longer than the front tires, and you save a bit of money over time.
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
ticki2
'68 Avion C-11
'02 GMC DRW D/A flatbed
bobbolotune
phil-t wrote:
I have been doing this once/year (5 to 10k miles) for 7 years - no issues, good tires and they will age out, not wear out.
You do which? You follow the manual and only switch the same positions side to side?
Lwiddis wrote:
Every vehicle owner’s manual I’ve ever seen discusses tire rotation and how to rotate tires on that vehicle. Does your manual discuss the manufacturer’s recommendation?
Yes. As I discussed in my original post the manual says to rotate the same positions only side to side. But my question came from what the service manager said at the tire place where I had the tires replaced. He said that they rotate back to front (he said that they do it every day) and if I had done that I would have gotten more life from the tires.
It makes sense to me that only switching the same positions side to side, as the manual says, is of limited value because with every other tire rotation the tires will end up in exactly the same place they started.
I’m still unclear. I suppose when in doubt it is probably best to follow what the manual says. Yes the front tires may wear out faster than the back tires but maybe that is just how it goes.
Grit_dog
Nomad III
Nomad III
And the rural shop wasn’t really wrong either. But again it’s situational.
Example, our truck with 37s had fairly new tires when we got it but the PO was well on his way to screwing them up.
I’ve been adjusting pressures and rotating as needed to the position needed even including flipping them on the rims now, to increase tire life.
Result, 40k miles ago, there was 3-4/32 difference between tires. And tread cupping on the front. Now, tires are almost equally and perfectly worn and still have 9-10/32 left center tread
This would have not been the case if I just blindly rotated in some pattern and used “recommended” pressures. At $2000 a set now (FJB) it’s worth understanding tires, imo.
Grit_dog
Nomad III
Nomad III
bobbolotune
There is no one “right” way to rotate tires that fits all scenarios.
Idk anything about dual rears having “different” pressure sensors which inhibit changing tire position. Although it makes sense if the rf signals from tires in the same proximity can not be differentiated from each other. (I have no knowledge though)
Bottom line, tire rotations “should” be based on tire wear and correcting any abnormal wear by putting it in the best location to do that.
And then there’s the issue of polished wheels, steel inner dual rims etc.
Generally in industry where gramps isn’t rotating tires every oil change, need it or not, rears stay on back and fronts get rotated side to side.
Maybe rears get rotated side to side to correct tread feathering.
If you notice rent and rear tires on a rwd feather in opposite directions. This is corrected by swapping side to side, or on a srw, corrected more efficiently by swapping straight front to back.
It is a rare day when I rotate in a X pattern on a srw as that generally is not the best option for increasing tread life.
If one is paying $ for tire rotations, also consider the cost of rotation vs how much tire life (also $) you are saving.
CA_Traveler
The best answer considering your TPMS is to follow the manual. You could do otherwise and likely not a issue.
There are many variables like: Duals should all be the same diameter so that the wear is the same, the inner dual is usually warmer, the outer dual temperatue is higher with sunshine, typical road crown causes more weight on the inner dual, turning has more effect on the steers, passenger side tires may have different wear, etc. These are likely minor concerns.
I see differences in PSI and temperature during a days travel but the above factors vary throught the day including ambient temperature. For most RVs that pay attention to the tires they age out and should be replaced to lessen any problems.
2014 Grand Cherokee Overland
Bob
Lwiddis
Tvov
When I had my F350, I "rotated" side to side. My 1987 F350 had limited slip rear end and creeper gear manual trans. The front tires would wear out long before the rear tires due to the tread on the fronts getting worn off when turning - fighting the rear duals wanting to go straight.
This was a work truck, rarely saw highway speeds.
When in doubt, do it like the owner's manual says.
2021 F150 2.7
eHoefler
For about 20 years of owning dually trucks, I have rotated the RR to the front on the first rotation of new tires, second time LR to the front, and if they last long enough, I rotate the RR to front again, etc.. I have manage to get all 6 tires replaced under milage warranty several time since all tires had worn with in 1/32 of each other.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
gbsteph
I have gone one step further. I rotate my spare into the mix with my inner dual wheels since it has the matching steel rim. I hate that the spare sits there and never gets wear on it except in emergencies. I just dealt with the tire pressure sensor being "off" when the spare got rotated into the mix. I recently purchased an inner tire pressure sensor to be installed onto the spare tire rim and was told the system will "learn" the sensor once it gets spinning. We will see. It can also be programmed at the dealer for a few bucks I'm told. So I rotate outer aluminum wheels clockwise, and inner steel wheels clockwise including the spare. Picture a triangle with the spare as the top point.
phil-t
Opinions on the best way to rotate differ, but the general consensus among most tire pros seems to be that a counter-clockwise rotation on each side of the truck is the best approach.
2014 Allegro 36LA
