โAug-30-2018 07:33 AM
โSep-02-2018 10:43 AM
โSep-02-2018 08:02 AM
โSep-02-2018 07:53 AM
โSep-01-2018 09:21 AM
ib516 wrote:dodge guy wrote:
If you have 3.42 then going to 4.10 will allow you to tow in OD. Best thing Iโve done. Iโve even heard of people going to 4.20 4.30 ratios. I went from 3.73 to 4.30. Best thing I have done. It let me use OD when towing.
The OD clutches in a 4L60E are tiny. I wouldn't suggest putting that load on them.
โSep-01-2018 05:39 AM
โAug-31-2018 08:38 PM
โAug-31-2018 08:18 PM
BenK wrote:
Not a complete comparison...
Like folks who compare a racer/dragster/etc vs towing with the same ICE, diff, etc is out of context
The hours at high throttle at +60MPH and heavy loads...going up inclines has a much higher duty requirement than racing and 4x4'ing out there.
I've pulled 4x4's out that twisted axle splines and/or broken axles...so much depends...
โAug-31-2018 05:38 PM
โAug-31-2018 03:46 PM
blt2ski wrote:
Not to be a buster on this idea.......Depending upon the gear ring size, going lower than a 4.10 to 4.56 or even a 4.88, may put the teeth too small. So yes, you get use of OD towing. BUT, if you stomp on the go pedal in 1st gear, you may break the R&P teeth! If you have an 8.5" or smaller setup. I would not go smaller than a 4.10. If you have at least a 9.5, then a 4.56 may be the largest you want to go. I really doubt you have one of the 10.5 or larger ring gear setups with a 1500, those, into the 5.xx would be doable.
Also going lower, you may need to change out the axel shaft itself, as the current setup may not handle lower gear sets too! A new 9.5 or larger RP from a 2500 may be in order. Now you have to change out the 8 lug to a 6......any way, I'm going to quit typing, as some of this may be an issue, or it may not!
Just throwing another monkey wrench or 2 or 3 into the thought pattern here!
Marty
โAug-31-2018 02:28 PM
โAug-31-2018 11:33 AM
โAug-31-2018 10:15 AM
Marty
โAug-31-2018 10:03 AM
โAug-31-2018 06:28 AM
Marty
