Jack is too short
Chucknbob
So the main jack for my Jayco 165 doesn't lift the front of the trailer high enough to be able to lift the trailer off of the hitch. I have to slide a 4" block of wood underneath it to be able to lift it high enough.
Unfortunately, I've not been able to find any info to tell me if there is a wheel or something that may have been there at one time to make it higher. Does anyone know of something permanent I could use to increase the lifting height of the jack? The block of wood works but it feels a little rednecky (yes, that's a word).
34 REPLIES 34
colliehauler
Put me in with the rednecks that use a block of wood 6x6.
mhardin
Bill & Kate wrote:
I have an 8" length of 8x8 and a 6" length of 6x6 that stack very neatly under my jack. There is also better stability with the jack extended as little as possible.
Same here. The shorter the jack, the greater the stability.
2013 Ford F-350, 4x4, Crew Cab, Long Box.
2001 Jayco Eagle 266 FBS.
2014 Heartland Elkridge 37 Ultimate.
F1bNorm
It's probably a good thing we need to put a block under the jack. As is, I still occasionally scrape the jack on driveways and have on occasion straddled fallen objects on the road. If the jack were made taller for more extension,it could block rear doors and tailgate access.
Norm
F1BNorm
Bill___Kate
Bill & Kate - Stone Harbor, NJ
w/ Bailey (standard poodle) and Zeke (partipoodle)- both rescues
2018 Ford F-250 Super Duty Crew Cab w/ 6.2L gasser
2014 Forest River Wildcat 272RLX fifth wheel
opnspaces
Navigator II
Navigator II
I have a 6x6 or maybe it's an 8x8 piece of wood that's always under the tongue jack unless I'm hooked to the tow vehicle.
VAfan
Jack is โ€œvertically challengedโ€!
Sorryโ€ฆ..been one of those daysโ€ฆโ€ฆ
wanderingbob
I am no longer a hillbilly-redneck ! I an now an Appalachian American !
GaryWT
I have never tried to remove it without a 4 inch block of wood under it. Carry it with us always.
ME '63, DW 64, (DS 89 tents on his own, DD 92 not so much), DS 95
2013 Premier Bullet 31 BHPR 2014 F350 Crew Cab 6.2L 3.73
Calicajun
Hondavalk wrote:
https://www.youtube.com/watch?v=XWZxjfaufkY
This should work for ya.
That what I use on my 31' trailer and it works great.
2014 Heartland Wildness 2775RB, 2015 Ram 2500 4x4 Mega Cab
coolbreeze01
Need a 4x6 to be proper.......two high to be professional grade and 3+ is approaching rednecky :B
2014 Sandsport 26FBSL
campigloo
I use a gizmo called a flip foot. Extends the shaft about 6 inches and automatically folds under the frame when retracted. Works real well, paid about $50.00 for it.
NanciL
Doesn't have to be "red-necky"
Do what I did. I made a solid box out of sturdy wood, and spray painted it gloss black.
I also made four of them a little shorter for my stabilizers so the spread of the scissors wouldn't be so high and also painted them black.
I have had a few people ask me where I bought them
We use the Trailer four months every winter, so I give them a fresh coat of paint once a year.
Jack L
Jack & Nanci
nickthehunter
Nomad II
Nomad II
filrupmark wrote:
I guess most of us are Rednecks.
That's what I was thinking. I can't think of a time when my jack didn't have a 4 x 4 under it (except when it is hooked to the truck).
RoyB
Does your trailer jack have one of these under it. Mine also came with WHEEL adapter as well...
These are available from ETRAILER or AMAZON
I always put 2X8 wood sections under all my jacks to keep them from digging into the dirt. A larger flat area gives better support
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
goducks10
Stick a block of wood under the jack.
