Jump box for dual battery 7.3 diesel
F-350shortBed
I started thinking about items I might need as a new RV’r, jump boxes came to mind. I’ve looked at a few video’s online of large diesels requiring higher amperage jump boxes when their batteries are dead. I’ve never owned a jump box and I know there are lots of new smaller lithium modules and old schools larger varieties.
Please give your choices and rationales.
29 REPLIES 29
theoldwizard1
My 2¢ !
Just because you buy a name brand jump box and pay a lot of money for it does NOT mean it is the best value ! NOCO has a good reputation, but not everyone is happy with theirs !!
The opposite CAN be true ! I have great respect for the author of this video and value his opinion New KING of Jump Starters ?
TrekPow TJ2500 18000mAh Portable Jumper Box(Up to 9.0L Gas/8.0L Diesel Engine
I couple of features I really like
• decent carrying case
• waterproof (with the covers installed)
• built in flashlight
• built in USB charger/powerbank (USB-A and USB-C)
• recharges via provided standard "phone charger" (including ones that plugs into a cigarette lighter( via the provide USB-A to USB-C cord.
Grit_dog
Navigator
Navigator
time2roll wrote:
I carry the NOCO GB70. Have not used it.
I would have no issue using my trailer deep cycle batteries to jump start a vehicle.
Except pulling and re-installing 4 batteries twice is at best an inconvenience. At worst impossible either due to ability or battery fitment.
And depends on conditions. Cold weather, may take both batteries (especially in a 7.3 Powerstroke. Those things are cold blooded). Warm weather, 1 good battery will light off a diesel pickup no problem.
Using camper batteries imo is a last resort type of thing, if they even work.
For the “I bought _____ booster. It should start my rig, haven’t tried it though” folks.
If you’re actually concerned about getting your vehicle started at an in opportune moment, unhooking the battery(s) and testing the jump pack is super easy.
time2roll
PastorCharlie
RoyF wrote:
Should camper batteries be used for engine starting? I have understood that deep-cycle batteries are not designed to deliver that kind of high amperage. Would engine starting harm camper batteries, or not?
"There are times I almost think
I am not sure of what I absolutely know."
(The King and I)
Not unless they are discharged too low. I have sufficient batteries and sized cabling that I could do mild welding with them.
Yeti_plus
I carry 2 of the small lithium battery jumper packs. On my 06 GMC, the batteries died when my wife had the truck. I was in the midst of a breakdown repair at work so couldn't leave right away, so she called CAA. The repair didn't take as long as I thought and I arrived 2 minutes after the CAA booster service. His booster pack wouldn't start the Duramax, so I put my big old booster pack on the second truck battery and it started right up.
This experience caused her to want to carry booster batteries for our travels. A major Canadian retailer suggests that their battery packs can start up a 6 liter diesel, so using that and my experience, I opted for 2 of the larger sized lithium packs from Amazon.
So far I have not had to boost my truck. But the lawn tractor, the Honda scooter and somebody elses' truck in a campground in Newfoundland have all been easy starts for just one of the packs.
2014 Chevrolet 3500 CC 4X4 Duramax, Tork Lift Tiedowns, TorkLift Fastguns, Superhitch and supertruss
2009 Jayco 213 SOLD
2008 Bigfoot 25C9.4
theoldwizard1
Once, probably not. You don't want to subject them to an extremely long crank time.
Grit_dog
Navigator
Navigator
The little 800-1000A Lithium jump packs will fire up a cold Chevy 5.3 V8.
I have one for my Snowbike but disconnected battery and tested it on my work truck. It lit off the truck, barely.
They make 2000A ones for around $100. But I’ve never tried to dead start a diesel pickup with them.
Kayteg1
You'd need #2 cables to jump engine from camper batteries.
The batteries went very long way in last decade.
I was picking up diesel truck from auction and batteries were at 0 due to somebody leaving key in on position.
The yard guy brought jump box in about foot size, so I told him it is not going to work on diesel.
But he had 2 of them and small lithium batteries started big diesel just fine.
I have cigarette pack-sized jumper pack who delivers 300 amp.
Hard to believe, but it did turn my Honda 3000 generator just fine.
RoyF
(The King and I)
PastorCharlie
All the 7.3 Diesels that I have seen, and I have one, carry two 850 + AMP parallel wired batteries for the chassis. It is near impossible for both to die beyond a start up without being neglected in maintenance. I have two of them sitting in my shop due to one morning during a recent cold spell I had to activate the glow plugs twice to get a start up. My next trip was to get two new ones. They are maintenance free except keeping the terminals and cables clean. Six years is a good life for the batteries and they had served well.
Unless the two batteries are both totally dead a 750-850 AMP battery booster should start a good tuned 7.3 with the aid of the weak chassis batteries. I recommend under such time to activate the glow plugs 2-3 times before attempting a start. Preheat the cylinders and do not depend upon the compression solely to do so. If equipped with an engine warmer use it before attempting a start. That 15-40 engine oil gets stiff sitting in cold weather.
Buzzcut1
Nomad II
Nomad II
This is where two big 12v group 31 AGM's in the camper come into play in an emergency
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Definitely do your research and get one that's up to the task.
Case in point: Couple winters ago my 3500 diesel was parked in a customer's driveway most of the day. That was the day both batteries decided to go south.
Mr. Gadget man brought out a piddly little jump box, insisting it would start my cold diesel. My skepticism was verified when it did absolutely nothing to help. 2 clicks from the solenoid and the box just whined a bit.
I had to get a ride home, get my big stout battery charger and run it a while to get me going.
Would a bigger jump box have done the trick? Not sure, I know little about them.
All I'm saying is be sure it has enough oomph to crank a dead diesel.
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
KD4UPL
I would recommend a NOCO GB70 or GB150. I have the GB70 and the battery dealer I bought it from said it was big enough to start my Duramax even though that's technically over it's rating of a 6 liter diesel. I've only used it once to start my 6.0L Suburban but it worked great.
jimh406
I’m a big fan of the jump boxes. I have bought several, so they will be available when I need them. They frequently go on sale on Amazon with a lot of competition of different brands and more powerful models can be had for less than $60 pretty often. I prefer the ones that come with cases and end up being 6x6x8 or so. Fwiw, they work better than my older jump box that is 4 times the size. As noted, they can also be used to charge devices like phones etc.
I’m also a fan of power stations. I’ve bought a few of them as well. The prices vary widely. I bought a few on Amazon that are 300 watt size for less than $180. I’ve already used one for a minipower outage. Our power goes out occasionally but usually only an hour or so. They are cool to provide AC where you need it without cords to a generator.
NRALIFR
A jump box big enough to start your 7.3L diesel on its own is going to be a pretty healthy and costly jump box. Probably about 3000+ Amps. Like all devices with their own batteries, the batteries can either last a good long time if you’re conscientious about maintaining them, or they can have a short life if you neglect or abuse them.
For my use, instead of buying a jump box big enough to start the truck engine, and likely not get used for much else, I bought one big enough to start the built-in Generac in my camper even if it’s less than 100% charged.
I’ve got a NOCO GB40, and I use it to recharge USB devices primarily when we’re off-grid. That way it sees some use often enough that I know it’s state of charge. The chances of ever needing it to start the generator are pretty slim, but id never say impossible. I also don’t totally trust all this auto-magic BS on modern vehicles that’s supposed to keep the battery from EVER getting flattened. I occasionally get pretty far away from help, and like to have several backup plans available. Stuff like that always works perfectly for me.......until it doesn’t.
So, my advice would be to think about where you’re likely to be and what other equipment you will have with you, and how you’ll use it to help yourself if the worst happens.
2001 Lance 1121 on a 2016 F450 ‘Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam types………..Let’s Go Brandon!!!
