โJun-19-2021 07:19 AM
2007 Dodge Ram 1500 4x4 5.7 Hemi (3.92 gears)
Prodigy brake controller,Weight Distribution Hitch
2021 Coachman Catalina 263BHSCK
โJun-21-2021 06:05 PM
โJun-21-2021 05:05 PM
โJun-21-2021 05:00 PM
ScottG wrote:
But even newer 1/2T's have clutch fans. My neighbor has a late model F150 with HD towing pkg and it has a large clutch fan - because that's what it needs to keep temps down.
Also, you do not want to add an electric fan to a system that already has a clutch unit. The electric fan will block airflow and cause performance issues. Besides, pusher fans don't work nearly as well as pullers.
โJun-21-2021 01:07 PM
Cummins12V98 wrote:ScottG wrote:Devo the dog wrote:
Put on an electric fan.
No electric fan can move as much air as the stock clutch fan on these trucks. That's why they use them.
I agree on that if he had a Diesel. Some of the electric fans do a great job on gassers.
โJun-21-2021 12:51 PM
As of 2021 all domestic 1/2 tons come with OEM e-fans. The much smaller fan to shroud clearance has a decent increase in efficiency, hence Ram gets away with 900 - 1000 watts instead of the 5 - 10 hp mechanical fan.
But in the OP's case, something is not right. Even a 10 hp parasitic draw shouldn't decrease speed from 50 to 40 mph, that's closer to a 50 hp draw.
โJun-21-2021 12:38 PM
โJun-21-2021 11:02 AM
โJun-21-2021 06:07 AM
โJun-20-2021 10:25 AM
โJun-20-2021 07:04 AM
โJun-19-2021 02:41 PM
โJun-19-2021 01:24 PM
โJun-19-2021 12:54 PM
โJun-19-2021 10:11 AM
โJun-19-2021 10:01 AM
