Lost vent flap for exhuast shroud
t-smith
Anyone know where I can order a replacement flap online? I didn't put the tabs over top of the flap when I left, and when I got home - the flap was no longer in the shroud.
Thanks.
2018 F250 CCLB
2012 Grey Wolf 28BH
26 REPLIES 26
JJBIRISH
I was not aware of what brand the op is looking for, I didnโ€™t know that was establishedโ€ฆ
I also lost the damper from a Ventline brandโ€ฆ
Love my mass produced, entry level, built by Lazy American Workers, Hornet
bfourman
samsontdog wrote:
I cut a very stiff screen to fit in its place. I found its better this way as the DW never turned the fan on as she said it was noisy. I like fresh air anyway as this lets in some
Same here. I haven't noticed any water intrusion from towing in the rain either.
'00 GMC Yukon XL K2500 - 6.0L, 4L80e, 3.73s, P3, AirLift, BlackBear tuned.
'14 Aerolite 282DBHS - Andersen No-Sway
facory
The part that he was looking for is made by Heng Mfg., Ventline is not a replacement. Even the cutout is a different size. Which is best? Flip a coin. Ventline is probably easier to find retail.
2008 Cruiser RV Fun FinderXtra
Ford F150 Lariat 4x4 SuperCrew 5.4L 6.5' Bed 150" WB 3.73
Schwinn Mountain Bike
JJBIRISH
A new complete Ventline cost under $7
http://www.rvpartscenter.com/ProductDetail.asp?PID=20263&SID=9&DID=105&CID=287
cjoseph
Save your money. Make something better. The tabs will break too easily.
Ours went. My dealer only had the whole assembly for like $10 to $15 (can't remember exactly) I thought I'd just bend and insert the flapper rather than take off the whole housing and reinstall the new. Well, one of the tabs broke while I was trying to put it in, and I was trying very gingerly to insert it.
Chuck, Heidi, Jessica & Nicholas
2013 Tiffin Allegro 35QBA
dadmomh
It's sorta SOP for campers. The replacement for our '07 ROO was $35 incl shipping. Our new TT has a totally different type, so maybe.......but that's still part of our "close up and get ready to leave" procedures. Not in the mood to invest again.
Trailerless but still have the spirit
2013 Rockwood Ultra Lite 2604 - new family
2007 Rockwood ROO HTT - new family
2003 Ford F-150
4 doggies - We support Adopt/Rescue.
Sam, you were the best!
Cubbie, Foxy, Biscuit and Lily - all rescues!
Ray552
I also forgot one time and now have a screen in place. Seems to work and I do not have to remember to Close it.
facory
Here is where you can find the replacement vent. I always carry a spare in case we forget to fasten the flapper before traveling.
http://www.dyersonline.com/heng-s-polar-white-range-exhaust-vent.html
tahoemc
mailman wrote:
The flapper shown in Gene&Ginny's post is what everyone is speaking of. Over the years and all three of our TT's, I have replaced seven or eight of these flappers. On occasion we forgot to fasten them down, and some disappeared with the locks still in the lock position. Last year we made it to the next CG and when I went to release the locks on the flap, it just fell to the ground. I came up with a fix to correct the manufacturers mistake. I took the flapper, trimmed the top rib off, cut an aluminum coat hanger just as long as the original pins and flapper were. I used Loctite STIK'N SEAL Outdoor Adhesive and glued the wire permanently on the flapper. Once the adhesive was completly cured, I bowed it just enough to slide it into the housing. We have made numerous trips with it since, and I still have the same flapper. The plastic of their flapper pins are just flimsy.
I used aluminum as eventually steel might have caused problems with rust.
Well, just experienced this problem with this product/manufacturer and used this repair mod last night with a slight twist. Used gorilla glue and aluminum foil tape. So far so good - THANKS for the idea. Funny thing is, we had same vent flapper on previous TT for 9 years, never had a problem. Have had the 5'r for 15 months, it broke last week. Go figure????
2004 Ram 3500 Quad 4x4 Cummins w/auto 4.10 Reese w/ slider
2012 Dutchmen Denali 262rlx w/Moutain Package
mailman
Don & Deb
US Army Retired (CW2)/US Postal Service Retired After 16 yrs
2011 Ford F250 Lariat Crew Cab 6.2 V8 4x4
2010 Keystone Cougar 26BHS
Ford In Dash Brake Control by Tekonsha
Hensley Arrow
Gene_Ginny
I am guessing it is the flap in this picture.
Gene and DW Ginny
[purple] 2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363[/purple]
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
Go_Dogs
stitchinsue wrote:
What and where is this part you are talking about? I have a grey wolf also and haven't seen what you are talking about.
It's the vent from the oven hood. There's a flap held in place with little flippers. If you forget to close the flap with the flippers, it might fall off on the road.
rockhillmanor
Standard part at any RV store. Look closely you most likely will see that it is cracked and just buying the flap isn't going to help. They sell the whole replacement unit.
They rattle and fall off too often for me so I stuff a cut to fit hard foam in mine when traveling. Just have to remember to take it out if you cook on the stove.
2Macs
I lost mine also. Replaced it with a stainless steel screen I made from a 12 X 12 sheet I got from W. W. Grainger.
Ed & Michele :C
