โJul-16-2013 05:30 AM
โJul-27-2013 04:04 PM
โJul-27-2013 03:33 PM
โJul-27-2013 11:11 AM
โJul-27-2013 10:01 AM
โJul-27-2013 08:48 AM
โJul-27-2013 05:38 AM
Gerald1755 wrote:
5740 lbs
Without myself in the truck
Little more than 1/4 tank of gas
I figure the additional equipment just about makes up for not having a full tank.
Taking the 5740 from the 7200 gvwr I only get 1460 available cargo.
the tag on the drivers door says never to exceed 1383 lbs cargo. The numbers just don't add up.
โJul-27-2013 03:44 AM
โJul-19-2013 07:25 PM
blt2ski wrote:
To me, the op has a door sticker that says 1560 lbs of payload, his gvwr less 1560 is about what the truck should weigh, sitting there, with nothing in it other than a full tank of fuel!
โJul-17-2013 07:42 PM
โJul-17-2013 09:46 AM
โJul-17-2013 03:30 AM
โJul-16-2013 07:39 PM
BenK wrote:rightyouareken wrote:BenK wrote:
1560 payload
This is based on the OEM's 'curb' weight and only has one 150lb driver
and the tow option.
Unless you have that stripper model and only weigh 150lbs, then that
1560 lb payload does NOT apply to your TV
Reference the below diagram to make sense of what I just said
The payload rating doesn't assume a 150 lb driver. The sticker says "The combined weight of occupants and cargo should never exceed..." so if he's getting this number from his sticker on the door that is amount of weight he can add to the truck as it left the factory with full fuel. Anybody in the truck, cargo, and tongue weight, must be less than that amount.
Hidden in that the payload is determined using the 'curb', which has
one 150lb driver and liquids (some full, some partial)
โJul-16-2013 04:02 PM
Proteus wrote:
I guess the question is, why haven't domestic car makers caught up? Jeep is putting a similar 3L TDI in the new Grand Cherokee (sourced from Fiat). Both can get 30mpg+ on the highway (I'm getting 28 now in my break-in period). I'm sure it drops in half with a heavy trailer though...
โJul-16-2013 01:53 PM
