New battery time
Hemling
We never boondock with our TT, and since we now live in a place where it can be stored on property, it will always be plugged in. Do I really need a deep-cycle battery? Probably the only time it will ever be disconnected is winter storage, and then I'll probably disconnect the battery and keep it inside.
11 REPLIES 11
Boomerweps
If you going to pull it for winter anyways, bite the bullet and go LiFePO4. Half the weight for lugging it around, you can run it dead and not hurt it, unlike flooded lead acid. You can also mount it in any orientation, INSIDE with no dangerous outgassing. Itโ€™s only down side is INITIAL cost (but itโ€™s longevity defrays that) and charging while frozen can damage it (pull out during winter or pay a little more for an internal Battery Management System that shuts off at or near freezing).
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
pianotuna
Nomad II
Nomad II
Hi,
Any battery will do. Make sure the converter is not a "battery eater".
Regards, Don
Hemling
Ha! I need to update that. Yeah. Um, I live in Northern WI now.
rhagfo
You list a Miami, FL location, and talk about โ€œWinterโ€ storage.
Hemling
Sorry - I should clarify. I was thinking of just going with a car battery. I used to live somewhere that prohibited having a TT on my property, so it was in storage and went through a lot of charge/discharge cycles. Now, it will be plugged in all the time.
ktmrfs
Agreed, no need for a true deep cycle battery setup. A "marine/RV" battery will be more than adequate, and cover you for the rare occasion when you need the battery, like when shore power goes out... A marine/rv battery will be about the same cost as a straight starting battery, but will do last longer if you have occasions where you do use the battery long enough to discharge it more than about 20%.
RV/marine batteries are a compromise between a starting and deep cycle battery. Lower CCA than a starting battery, Longer cycle life than a starting battery but lower cycle life than a true deep cycle battery.
2011 Keystone Outback 295RE
enblethen
I would get an RV group 24. A small battery may not have sufficient power to run electronics going down the road such as refer.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
opnspaces
Navigator II
Navigator II
No you just need a cheap 12 starter battery. You could also probably get a 12v motorcycle or lawn tractor battery.
For your needs the battery is only there to provide 12v power for the emergency breakaway system in case the trailer gets disconnected while towing.
Boon_Docker
No need for deep cycle batteries if the trailer is always on shore power.
Krusty
Are you asking if you need a battery or specifically a deep cycle battery?
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
nickthehunter
Nomad II
Nomad II
If it was me, Iโ€™d get the RV/Marine deep cycle
