โMay-24-2015 03:56 AM
โMay-24-2015 05:36 PM
majorgator wrote:No one here said the Tow/Haul mode would keep a vehicle out of overdrive. But the tow/haul mode will automatically select the right gears and keep the transmission from continually hunting through the gears including overdrive.Jack_Diane_Freedom wrote:
Just engage the tow haul button and go the computer will select the right gear.
This is not entirely accurate. While the Tow/Haul button will change shift points and thus prevent you from advancing gears at the lower RPM's, it will not keep you out of overdrive during heavy tow modes. The best and really only useful way to determine if OD is OK is to drive and experience it yourself. If it's shifting in/out of OD frequently, then don't run there. Keep an eye on trans temps and monitor the shifting.
โMay-24-2015 03:24 PM
B.O. Plenty wrote:mr61impala wrote:In my last Ram 2010, it would go into 6th when using haul/tow but would not up shift until it hit about 64-65 mph. I would then down shift to 5th at about 58mph.kaydeejay wrote:Jack_Diane_Freedom wrote:X 2
X3.
In our Ram Tow/Haul locks out 6th but it will achieve 5th, the first of two overdrives, albeit at a higher engagement speed. In fact all upshifts occur later and deceleration down shifts seem to occur sooner.
B.O.
โMay-24-2015 03:07 PM
โMay-24-2015 01:37 PM
โMay-24-2015 09:31 AM
scbwr wrote:
Refer to the owner's manual re towing in overdrive. I use overdrive when on flat terrain as long as the transmission doesn't start searching for gears. Use the tow haul mode and let the transmission shift gears and see how it does. But, see what the manual says about towing.
โMay-24-2015 09:19 AM
X3.
โMay-24-2015 09:12 AM
โMay-24-2015 06:35 AM
โMay-24-2015 06:02 AM
โMay-24-2015 05:34 AM
โMay-24-2015 04:58 AM
โMay-24-2015 04:47 AM
โMay-24-2015 04:08 AM
