May-22-2020 11:36 PM
May-24-2020 12:54 PM
Lwiddis wrote:
Why not follow the manufacturer’s specifications?
May-24-2020 11:25 AM
Cummins12V98 wrote:Fisherman wrote:
Easiest way is to use the chalk line across the tires to find optimum PSI. Google it. Short version, take common blackboard chalk and make a couple heavy lines across the tires(all 4). At unloaded weight, you may find 50-55 psi is good for the front, 40-45 for the rear, the chalk will wear off evenly across the tire after 1/4 mile of straight rolling. Walmart parking lot on a dry sunday morning works well. If outside is gone, pressures, too low, if the middle is gone, too high pressure. Unloaded I used to run 52 front, 45 rear. Loaded 60 front, 70 rear.
You towing a TT or 5er?
May-24-2020 09:44 AM
BenK wrote:
Know won't help much...but have to try...
As an example...consider going from a LT class tire to a lower class tire...like P class
Using the current posted logic...would it then make sense to air up your new P class tire using the higher class LT tire's PSI's ?
The P class might blow up...
May-24-2020 09:40 AM
bguy wrote:
The P tires called for 35. When I switched to LT I still used 35. I actually aired up for towing but eventually concluded that the LTs did just fine and rode and wore well at 35.
May-24-2020 09:03 AM
May-24-2020 08:43 AM
May-24-2020 08:15 AM
May-24-2020 07:43 AM
May-23-2020 09:13 PM
MitchF150 wrote:
I upgraded to "XL" rated tires for my F150 with 275/55/20 tire size.
They are 50 psi max and have a load rating of #2833 per tire at full psi.
Since the rear axle rating is only #4050 on my F150, I feel it's okay.
I run them at 35 in the rear and 40 up front when not towing. I'll bump them up to 50 on the rear and 45 up front when towing.
Just what seems to work for me on tire wear, comfort and peace of mind..
LRE tires in the same brand/AT were about #20 heavier per tire and cost a heck of a lot more.. Sure, if I had a 25 or 35 series truck that's what I would get, but I just have a wimpy 1/2 ton, so I make due... ha, ha... 🙂
It's just what works for me.. Since you already have the LRE tires, I'd just run them at the different psi settings based on your actual weight like you have already researched.. Overkill? Yes, but you got what you got so just run what works best for you..
Good luck! Mitch
May-23-2020 06:53 PM
May-23-2020 06:50 PM
CapriRacer wrote:I believe my truck with common P tires took 32 psi. My factory options included LT and call for 35 psi on the door sticker. Same size tire.
Totally wrong answer!!
The correct answer is: If the numbers in the size are all the same, in order to carry the same load as a P type tire does, an LT type tire has to use 15 psi more (more or less. Precision isn't necessary here!)
May-23-2020 06:06 PM
May-23-2020 06:04 PM
agwill wrote:
Take a chill pill way too much worrying inflate to rated tire pressure listed on sidewall of tire.
May-23-2020 12:54 PM
