โMay-30-2016 12:21 PM
โJun-06-2016 07:02 AM
โMay-30-2016 10:04 PM
โMay-30-2016 07:32 PM
โMay-30-2016 06:11 PM
smkettner wrote:
Do check the interior install. Remove the interior trim and take a look for poorly sealed transition to the ducting. Also verify if you have a plenum divider that it is well placed and sealed properly. This divider separates the air coming in and going out. If it is not installed well some of the air can just circulate within the unit.
โMay-30-2016 05:40 PM
โMay-30-2016 05:29 PM
โMay-30-2016 01:45 PM
โMay-30-2016 01:28 PM
โMay-30-2016 01:12 PM
โMay-30-2016 12:52 PM
โMay-30-2016 12:49 PM
โMay-30-2016 12:48 PM
KD4UPL wrote:
Should have worked better than that. Should have been putting out colder air than that. Have you cleaned the filters and the fins up under the shroud? I'm guessing it's low on refrigerant. That would normally indicate a leak.
โMay-30-2016 12:42 PM
โMay-30-2016 12:37 PM
