โSep-02-2015 06:15 PM
โSep-04-2015 06:45 PM
โSep-03-2015 02:29 PM
โSep-03-2015 09:31 AM
camp-n-family wrote:
Just returned from a 3400km trip which took us through some pretty good hilly areas around the Finger Lakes of New York. I tow with the combo in my signature. Trailer weighs 7600lbs loaded.
Overall the truck towed ok but there were a couple of hills where it really struggled. It is the smaller 5.7 Hemi engine but I never encountered this problem with my old similarly powered Tundra. The Tundra pulled the TT fine which is why I went with the Hemi instead of the diesel. (6.4 was impossible to find at the time of purchase) I'm wondering if there is a problem or if it's just the tall 2nd gear.
On 2 seperate occasions we had to start a climb of a fairly steep, long hill from a stop. The truck would pull hard and accelerate quickly in 1st up to around 5500rpm and then shift into 2nd. That's when it would struggle. The Tundra would continue to pull hard and accelerate, then shift into 3rd etc. The Ram just died and couldn't even hold speed. The shift into 2nd would drop the RPMs right down to 2500, out of the power band and it would bog down. Speed would keep decreasing but it wouldn't shift back to first. There was no way to get it into the higher RPMs of 2nd gear where the power is. I had to drop it into 1st and was stuck holding it at 5000rpm (~25mph) to climb the hill. The drop in RPM between 1st and 2nd is too great.
Is it normal for this truck and what others have experienced? I expected better. It was a fairly steep grade each time but only pulling 7600lbs of its rated 13,500lbs. The Ram does weigh 800lbs more than the Tundra did and has 4.10 vs 4.30 rear gearing but I still would have thought it could accelerate uphill, or at least hold speed.
โSep-03-2015 08:42 AM
โSep-03-2015 07:55 AM
โSep-03-2015 07:27 AM
โSep-03-2015 07:19 AM
ib516 wrote:
Mine will do 40 mph in 1st gear with stock tires and 4.10 axles at 5000 RPM+. I think something is off with your figures.
VIDEO
โSep-03-2015 06:59 AM
Can you check the rear end to ensure it is in fact the 4.10? Seems odd that it couldn't pull that unless something was off or you're a lot heavier that you think.
Mine does that too but I have 3.73 gears. I would think 4.10 would get it done. What size tires are you running?
Is it the same trailer for both the Tundra and the RAM?
If you were pulling a 6500lb trailer with the Tundra and a 10,000lb trailer with the RAM, it's not a fair comparison.
The HP output of the two engines is comparable, but the RAM is heavier, geared differently in the transmission, and has a shorter axle ratio. What you bought was mostly the additional payload capacity and suspension rigidity in the RAM.
โSep-03-2015 06:26 AM
โSep-03-2015 06:25 AM
โSep-03-2015 06:05 AM
โSep-02-2015 11:22 PM
โSep-02-2015 10:37 PM
โSep-02-2015 08:44 PM
Did you stand on it?
Did you try manually selecting 2nd?
