Mar-20-2017 12:27 PM
Mar-29-2017 09:12 PM
Mar-29-2017 06:16 PM
Mar-29-2017 08:00 AM
Perrysburg Dodgeboy wrote:
That will all change with the next Ram. They have decided to play the 3/4 ton under a 1/2 badge game also. The new 1500 will get six lug axles like the others along with a bump in the HP/TQ numbers for the baby diesel and other changes to bring it up to Ford's payload rating.
Honestly if I wanted a 3/4 ton truck i would buy a real 2500 not a want-to-be truck. But that is what the sheep want so FCA/Ram is finally bowing down. Whatever sells trucks I guess.
Don
Mar-29-2017 02:49 AM
Mar-28-2017 10:06 PM
I don't know blt2ski, Dad's 1973 C30 454 auto towed our fiver from NW Ohio to S.Cal without any issues what so ever. That thing was fast for a big ole crew cab pickup.
As for Alex yep had Ford sent a truck with the 4.30 gears they would have been very close to the Ram. But they would Not and I repeat NOT been the MPG champs. That seems to be Ford's number one thing, being the MPG King. When they get their little 3.0 diesel on line in the f-150 then they will recapture the crown in the half ton market.
Don
Mar-23-2017 04:31 AM
Hannibal wrote:transamz9 wrote:Hannibal wrote:
My 2010 lethargic 5.4L F250 spanks the creep out of all five HD Rams I've owned in overall owner satisfaction. :B
As it should beings it is at least 5 years newer than the oldest Ram you had/have. Why don't you meet me some where and you can compare it to my 2005 Cummins?
I bought all my Rams new. Within three years I was anxious to get a new truck for some reason or another. I had a 2005 2500HD. It was a nice truck except for the dreaded driveline vibe, ball joints, a/c evaporator and a rebuilt AAM rear end. It was a duplicate of the 2003 Cummins powered 2500HD before it which also needed an a/c evaporator and AAM rebuild in less than 100k. The F250 has needed an O2 sensor and a rear brake caliper. What are you wanting to compare?
Mar-22-2017 04:17 PM
Grit dog wrote:
They're all pretty impressive for small blocks considering what a gasser would do even as decent as only 10-15 years ago. GM is definitely long in the tooth but a venerable engine.
No complaints with the 2 6.2 F250s I've had. Never drove a Ram gasser since 2001 model.
What would propel the HD gasser market is getting a gasser with some real snort.
Between FoMoCo slapping a turbo or 2 on every engine they make and FCA pushing out a bevy of 400-700hp gassers in cars, one would think one of these mfgs would throw down on a real hp giant and watch them fly off the dealer lots!
Enough skepticism about newer diesels and enough weekend warriors pulling ever bigger trailers to have a decent niche I think.
Talking a mild blown 6.4 putting out 500hp or a 5.0 or 6.2 Eco BOOST.
Everything else with these trucks is built to handle the power....Who will be the first?
Mar-22-2017 03:28 PM
Mar-22-2017 02:26 PM
Mar-22-2017 07:46 AM
Mar-22-2017 07:23 AM
Don
Yup, 4.30 gears would have netted about 1-1.5 less mpg than it got, but it would have been right in line capacity and mpg wise with the others. Like I said before, in the end they are all matched quite well when equipped similarly.
Mar-22-2017 05:54 AM
Mar-22-2017 05:07 AM
Don
Mar-22-2017 05:03 AM
