Spare Tire replacement fuel tank
Bob_Vaughn
I see that Titan has released effective Dec 1st a 30 gallon spare tire replacement fuel tank. A fine idea except if you remove your spare tire what do you do with it? I would rather have the spare tire than have 30 extra gallons of fuel....
7 REPLIES 7
boogie_4wheel
If this was on a dually, I would just ditch the spare. Worst case is you lose a front tire and have to pull one of the rears to stick on the front.
On a single wheel you can bet I would be mounting the spare on the truck somewhere (front of bed, on a front hitch carrier, in the trailer, in the back seat).
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer,Transgo Shift Kit ISSPro Oil and LP pressure gauges, GDP 20/2 filters, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
4x4ord
In 600,000 miles I have never had need of a spare tire on a pickup. I would sell the spare and accept the slight risk of ever missing it.
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
mpierce
It would need to be mounted forward, otherwise 5th wheel trlr would not clear it.
Huntindog
Many forest service ( at least out west) are setup with two spares vertically mounted next to the bed rails, and then a large fuel tank where the spare used to be. They often are on rough enough roads as to need another spare, and in remote enough areas as to need more fuel.
This setup is popular with the 4X4 crowd for the same reasons.
In fact buying a used forest service truck with this setup ios what some will look for.
Naturally, not everyone needs or wants it.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
SoCalDesertRid1
I made a vertical tire mount for the pickup bed of my old dually. On my current, flatbed dually, I mounted the spare vertically, to the headache rack.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
DirtyOil
titan offers a "vertical" mount for the spare tire, so ya can mount tire in the box. not sure where it mounts though.
2013 RAM 3500 CTD Crew 4x4 Laramie
2014 Sprinter Copper Canyon 269FWRLS
GUTS GLORY RAM
Tachdriver
You could mount in the bed but there again lies the idea of having to secure it since it will be easy prey.
