Toast
Jack_Spratt
What is the easiest way to make toast?
Oven or stove top? I don't want to carry a toaster
BLT season is here, and I got a hankering.
Leprechaun 260 DSF
2017 Big Horn FL3750
'10 Yellow Lab to keep us on our toes.
15 REPLIES 15
jimh406
ReneeG wrote:
The alarms are super sensitive, too sensitive when cooking, which is why I originally purchased a toaster, plugged it in to test it, and discovered that with just the heat it generated, the alarm went off.
Sounds like your alarm may be faulty or in the wrong place. Otherwise, you should be able to use you fantastic fan or exhaust for the times you have significant smoke/steam rising.
Geewizard
lightly buttered in a pan.
2021 Winnebago Micro Minnie 1708FB
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
Xantrex Freedom X Inverter 3000W
2 Fullriver 105AH AGM batteries
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
jjjandrbaker
I use my microwave, but the toast gets harder than some people like it. More like a crouton. When I was growing up, my mom cooked toast over the flames of the stove.
Jim Baker
San Antonio, TX
travel blog and photos
kohldad
My Wife butters both sides and fries it in a skillet until golden brown. It's actually pretty good and doesn't take long.
Same here but we find it taste better just putting it in the not stick pan without anything, just the bread. We rotate it flat 180*, flip it, then rotate again 180*. How long in each orientation depends on how high the flame is and how golden you like.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
rockhillmanor
ReneeG wrote:
rockhillmanor wrote:
https://www.amazon.com/Camp-A-Toaster-CT1/dp/B007HRIYDY
OR
gsi stainless toasterhttp://theboatgalley.com/gsi-stainless-boat-toaster/
OR
Coleman 4 slice
If we do anyone of these to make toast, my alarm will go off in the RV! I make it under the broiler in the oven and occasionally frying it as stated here by someone else. Even using the oven method, we run a portable fan, aimed at the alarm, to prevent it from going off. The alarms are super sensitive, too sensitive when cooking, which is why I originally purchased a toaster, plugged it in to test it, and discovered that with just the heat it generated, the alarm went off. Never mind adding bread to the equation. Back it went to the store.
Here's the answer for you!
I do NOT cook anything in the MH anymore!! :B
Between the alarms, grease and god forbid you even think of using a hot oven in an RV while in Florida!
EVERYTHING gets cooked on this placed on either a small folding table or picnic table 'outside' the RV.
OR if you want to be even more of a minimalist this!
Cook outside the RV. AND.....
Both take up almost ZIP ZERO space when it's time to store them in the storage bays of an RV. :C
ReneeG
OR
OR
Coleman 4 slice
2011 Bighorn 3055RL, 2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3, 1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica, Mabel, and Melton
Phancy
Camp toast, butter cast iron pan brown toast. also makes a great way to make garlic toast.
2oldman
toast Dec 2014
djg
OR
OR
Coleman 4 slice
camp a toaster works great inside camper or on a coleman stove or bbq great for all purposes very cheap
Dave
2015 Livnlite Camplite TC10
1995 Ford F-350 dually 7.3 Diesel
rockhillmanor
OR
OR
Coleman 4 slice
b2egypt
I use cast iron on stove top inside or propane outside. Heat pan add dry bread flip a few times.... also warm bagels, reheat pizza etc by adding a iron lid, preheated on separate burner. Make sure well seasoned pan, sometimes I lightly oil, wipe dry with papertowel before adding bread etc. Love cast iron...need oven try old fashioned dutch oven.
Loving Life!
zulu52
Kind of like a grilled cheese sandwich with no cheese.
Zulu
DutchmenSport
You can always use one of these and just hold it under a slice of bread and move it around.
If you don't have one one these, I vote for the stove top.
3oaks
Toaster
Alternate: Stovetop. An oven would be inefficient and just add more heat inside during already hot weather.
I would say toast bread over an open fire, but you did ask for the easiest way.
