Towing capacity help
bpowell590
We are in the process of getting a travel trailer. We really like the Sportsmen Show Stopper that ways 4,500 dry. My tow vehicle is a 2013 GMC Yukon XL 4x4 with a 5.3 motor. I've done a lot of research and can't get an accurate traliering capacity for my vehicle but the RV dealer said it is 5,000. My question is will I be good towing a trailer with those numbers and does anyone have experience doing so?
Thanks for any input,
Brian.
15 REPLIES 15
bpowell590
Thanks everyone
APT
No cross posting.
GM rates those SUVs at about 5000 pounds with 3.08, 5500 pounds with 3.42, and 8000 pounds with 3.42/HD trailing package. GM never offered the 3.08 with HD trailing package, but I would feel comfortable at 6000 pounds with the 3.08 and a trans cooler in addition to the other towing equipment you have to buy anyway, brake controller and WDH.
A & A parents of DD 2005, DS1 2007, DS2 2009
2011 Suburban 2500 6.0L 3.73 pulling 2011 Heartland North Trail 28BRS
2017 Subaru Outback 3.6R
2x 2023 Chevrolet Bolt EUV (Gray and Black Twins)
MFL
Nomad II
Nomad II
misterpowertools wrote:
No doubt it's the 3.08 final drive ratio lowering the towing capacity. That by itself won't make towing unsafe...unless you have a breakdown from straining the rest of the drivetrain. You could re-gear both ends and be okay towing that TT which you will be adding about 1000 lbs to when it's loaded to camp. Less if you don't carry water. Regearing may be cheaper than trading in and a Yukon XL should be a fine towing machine for that trailer.
Yes, this and lack of extra cooling is the reason for 5,000 lb. tow rating. If you had 3.42 gears, with added cooling, same vehicle otherwise, the rating jumps to 8,000 lbs.
It would be a strain on the drive train, but not necessarily unsafe to tow as is. As a minimum, I would add better cooling capability, and tow in whatever gear allows the engine to rev freely.
Jerry
misterpowertool
2012 Nissan Titan KC Pro4X
2015 Genesis Supreme 19SS
2010 Honda EU3000is Gen
1968 Beautiful Wife
2006 Baby girl
tomkaren13
bpowell590 wrote:
If I go by the GVW of the RV I will be 1000 lbs over on my Yukon trailering capacity. Will that be okay?
No. You need a bigger tow vehicle. You and supplies are also included in as part of the vehicle towing capacity
NC_Hauler
I wouldn't want to tow 1,000# over my trailering capacity...You either need another TV to handle the load safely or look for a lighter TT...it is what it is...At least you're asking before jumping in...good decision,
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
bpowell590
bpowell590
Now that I looked up an a/c condenser it looks like it could be that. How do I know if I have a transmission cooler?
NC_Hauler
Brian.
#1...Do yourself a HUGE favor and forget dry weight, unless you're going to tow it completely empty...highly unlikely......use GVW of the unit to get a "real life" idea of how much you'll more than likely be towing, and get a more accurate tongue weight....Remember, safety first.
Also, its possible that with a WDH, your tow weight might go up some..3.08 gear ratio will not help if towing in the mountains at your max capacity..
B&W RVK3600 Hitch
mbopp
Two radiators, or a radiator and air conditioning condensed?
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
Bumpyroad
4,500 dry will grossly exceed your 5,000 lb. rating.
and dual posting is not desired.
bumpy
bpowell590
It has the 308 code GU4. How do I determine the cooling capacity? It has two radiators under the hood.
lbrjet
On your glove box door you will see an axle code. Look that up and report back. If you have the 3.08 axle that will limit you downward. Axle code and cooling capacity is what you want to find out.
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
bradyk
Do a search as we have been through this up many times in the pickup/trailer threads. Make sure on your payload numbers as you will probably run out of payload before the towing capacity......
2001 Chevrolet 2500hd Silverado LT 4x4 6.0L/4.10
2005 KZ Outdoorsmen 2605PF
Equal-i-zer 10K WDH
Champion 4000W Generator
Champion 2000W Generator x 2
Ken & Sandra
Yugi Dog, Jet Dog
