True, but scary, hitch story
brulaz
After a day's tow I discovered this:
It was very cold and raining very hard when I hitched up. And somehow I managed not to get the hitch socket completely on the ball before closing the latch. I remember that getting the Equal-I-Zer bars in place was unusually difficult, as you might expect. So there was a lot more pressure holding the hitch socket on top of the ball.
Still can't believe that the tongue didn't just pop right off the ball at some point during the tow.
Luckily the under-ball latch wasn't mangled much at the end of the day, and the hitch continues to operate fine.
Lesson? When conditions are tough, mistakes can be made. So be extra careful.
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
33 REPLIES 33
hohenwald48
2DHoop wrote:
Yikes! As I get older I try to have routines for doing things the same way every time in an effort to complete the process, but still, it's not hard to get distracted by external factors - unpleasant weather, someone yelling to hurry up, yahoos watching while you try back up into a tight space or the best of all: the boat ramp arguments between couples...
Glad this ended without incident.
That's why I never talk to folks who are hitching/unhitching. It interrupts their routine.
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
allen8106
I once had the same issue with a double jet ski trailer I was towing. Considerably different than yours due to the weight difference but mine was particularly scary because the tongue weight was very light. Light enough I can lift the trailer off the hitch by hand.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
2DHoop
2013 Arctic Fox 25P
2010 Dodge 3500 SRW CTD
byrdr1
DID the same thing once while towing the POPUP camper for like the first long tow. We left the house and the noise it made kept my wife asking what is that noise. I told her she just wasn't used to us towing a camper. We stopped 15-20 miles from our house to top off the fuel tank. I was doing a walk around due to the noise, I heard it too but brushed her off. I got to looking at the hitch set up and sure enough, the hitch was sitting on top of the ball and it was unlocked. Bought a hitch pin lock at that point and always made sure it was locked in and down on the ball.
Both of us were lucky. Stay safe,
randy
2014 F-350 SRW CC/LWB 4X4 6.7PSD
2011 Keystone Cougar 327RES
Happy Campin'
Randy
Piedmont area of NC
rolopayne
wow, that could have gotten ugly, thanks for the reminder to double check our stuff
RCPIII
2017 MXT 2920
2012 Chevy Z71
dodge_guy
Reality Check wrote:
Reason #42 why I hate balls..
No questions; it's latched or it's not.
Glad it worked out well for you...
What is that contraption? I know what a pintle hitch is but that looks sketchy at best!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Tvov
Glad nothing bad happened. I can see that happening from leaning over hitch, looking straight down. I've had similar happen with equipment trailers - which is why I've developed the habit of stopping and re-checking the hitch about 50 feet down the road - especially if something "feels not right" when pulling out.
Experience is a tough, but effective, teacher!
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
brulaz
sch911 wrote:
The process for connecting the arms generally includes raising the jack up above level to take the load off of the bars before connecting them. Do you follow that process? IF so you'd have found this situation.
I normally do this.
But really not sure what happened that day.
Perhaps in my hurry to get out of the foul Newfoundland weather I forgot.
TomG2
Nothing is foolproof. I had a driver hitch up a twelve ton trailer behind one of our tandem dump trucks with the pintle hitch upside down. All that kept it on was the flimsy little safety catch. He used the jack to raise the trailer up and into the hitch from the bottom side.
Reality_Check
Nomad II
Nomad II
'16 F550 CC, 4x4 with Link Ultraride air suspension, '18 AF 1150. Just so we can play with our snowmobiles, dirt bikes and fishing boat. And new 20' tag along...kayaks, bikes, mc's and extra water and food!!
Huntindog
This is a perfect example of why it is not necessary to lock the coupler when using WD... WD puts so much pressure on the ball that it simply cannot come off.
I would check the coupler and ball for damage. The coupler is probably OK, but I bet the ball is damaged. If it is, do not use it, as it will damage the coupler.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
Valkyriebush
I did that once on my utility trailer but caught it before pulling out. Glad no mishap.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
GaryWT
I agree that lifting the hitch/truck to connect the bars should have shown that the trailer was not on the ball. For my E2 hitch i always lift it so the bars just slide on.
ME '63, DW 64, (DS 89 tents on his own, DD 92 not so much), DS 95
2013 Premier Bullet 31 BHPR 2014 F350 Crew Cab 6.2L 3.73
CavemanCharlie
I had a 14 foot TT one that I towed 50 miles without remembering to lock the hitch. I got lucky and made it the whole way. No WDH on that little unit either.
hohenwald48
I guess that proves that a pad lock thru the coupler latch won't keep your trailer from being stolen.
