Aug-24-2022 04:58 AM
Aug-25-2022 01:42 PM
OP wrote:
With these low limits in mind, it would be interesting to start paying attention to all the F150s, towing 2000”-4000 pound trailer around and I bet most of them won’t have trailer brakes. I don’t say that to say it’s right or to justify anything I just think it’s the reality of how uninformed people are given all the hype the manufacturers place around the top rated tow numbers with no Asterix to prompt people to dig deeper. The F150 for example Has a unbraked limit of 1500 lbs.
Aug-25-2022 12:47 PM
Aug-25-2022 12:45 PM
Aug-25-2022 12:39 PM
Mike134 wrote:
nobody on any forum has seen a person pulled over for a weight check total internet rumor garbage
Aug-25-2022 11:40 AM
blt2ski wrote:See comments in redmkirsch wrote:
That's just it. It's a "recommendation" at best, not a "limit."
Those who have trouble with reading comprehension believe it is some sort of law, and that the F150 trailer towing shock patrol is going to spring from the bushes, throw them to the ground, stuff a sack over their head, and drag them off to a Siberian gulag if they try towing 1501lbs without brakes.
Actually, not that it will happen to most of us......
Ford "could" deny warranty issues to you if towing over 1500 lbs of unbraked trailer caused an item to brake, not last as long etc. who will tell them?
Or,
if you did say rear end someone, they have another item to check off against you in a civil court case.
Or
If you are pulled over by an LEO, the do a perverbial "field test" of your braking ability. [COLOR=]nobody on any forum has seen a person pulled over for a weight check total internet rumor garbageTypically on a level at 10-20 mph stopping within X feet. You don't meet test requirements. You get a red tag, can't move vehicle with trailer attached, assuming TV alone meets test requirement. Trailer get hauled off the road to a shop to get repaired. Then can not leave shop until an inspection is done.
These different legal or recommendations no matter what we are doing, being it hauling, towing, riding a bike, flying, boating etc. If you look at the issue one way, you're fine, but look at it from a different direction, assuming you're in the center of a circle, 360 ways to look at the issue, 359 of those ways can get you into major trouble, to one of the 360 ways getting you in trouble.
Like ALL things in life, look at the issue from more than one direction.
Yes, I've posted legal ways person is fine, but I also point out, not safe, or my recommendation etc at times too.
Marty
Aug-25-2022 11:11 AM
Aug-25-2022 10:48 AM
Aug-25-2022 10:05 AM
BB_TX wrote:tealboy wrote:
…. …….. The F150 for example Has a unbraked limit of 1500 lbs.
Where did you find this information? I have looked thru my manuals and cannot find anything addressing this. Not questioning you. Just curious where to find it.
Aug-25-2022 09:34 AM
Aug-25-2022 08:19 AM
Aug-25-2022 08:07 AM
Aug-25-2022 07:29 AM
It doesn't.
Just more made up rvnet c rap.
Just for gits and shiggles I pulled up a random F150 owners manual (2018) and it states something to the effect of follow your state's guidelines or requirements for max trailer weight without trailer brakes.
Aug-24-2022 06:33 PM
Aug-24-2022 06:19 PM
blt2ski wrote:
For what it's worth, GM recommends brakes for trailers over 2000 lbs in my 1500. Which, is about the max payload of the truck. Brakes it's 6700 or so.....blown that number out of the water. Identical V8 it's around 11,000 braked.
I'll stick to my earlier, if the trailer puts you much over the manufactures GVW, say max 500-1000 lbs, best to have brakes on it, no matter the vehicle.
Marty
Aug-24-2022 05:51 PM
