Aug-24-2022 04:58 AM
Aug-30-2022 07:42 AM
Wadcutter wrote:
I was one of the first certified CVEO in the state. Did it for a lot of years, taught CVE for a lot of years. There's so much hooey on this thread concerning what a CVEO supposedly said that you can discount it. As soon as someone mentions CVEO enforcement on your RV then just page right on by their post. They don't know what they're talking about.
CVEO = Commercial Vehicle Enforcement officer. Read that very first word. Commercial. You pulling your popup or 43 ft 5er down the road is not a commercial vehicle. None of the commercial vehicle laws apply. Why? Think about it. Because you are not a commercial vehicle. It's clearly defined in the FMCSA. It's obvious some who are attributing something to a CVEO have never read any of the FMCSA.
Manufacturers do not make the law. It doesn't matter what the manufacturer says is the limit. That is not the law. The state doesn't make trailers, the manufacturers don't make the law.
For the person who said they said saw 4 people sitting in court to pay fines because they overweight on their RV or boat. They were not overweight on their RV or boat. They may be over on their registration for the weight they were hauling but they weren't overweight. Totally different. Know the difference in terminology.
Generally weight limits per axle are 20K per single axle. Sometimes 18K depending on the class of the highway. You're not going to be overweight on a boat or RV axle limit. You may be over on your registration limit. If you only paid registration to haul 8K and hauling 12K that's over on registration and is an offense. Pay for the higher rate registration and you can haul it. But it's not overweight.
Aug-30-2022 07:32 AM
mkirsch wrote:JIMNLIN wrote:I don't see where anyone is saying manufacturers make the law or the state makes trailers. Manufacturers make the trailers that MUST COMPLY with the law, period.
Yeah..the OPs topic is about un braked trailers. Most replies have been on topic...until now.
I bought a '97 16' 2900 gvwr bumper pull utility trailer with tandem 3500 lb axles with one axle braking from my trailer mfg just down the road.
Now the trailer mfg says they don't single brake a tandem axle trailer anymore...thankfully. Dangz thing was dangerous with just half a load.
A 2900GVWR trailer with tandem 3500lb axles was dangerous with "half a load" i.e. 1500lbs? Must have been one poorly built trailer.
You must have some numbers crossed around.
Aug-30-2022 07:04 AM
blt2ski wrote:
Scooby,
As I understand Federal Bridge Laws for max weights. Everyone, commercial, personal use per say gets 20k per axel. BUT, you can get limited in weight by the lack of distance between them. 0 to x' is 17k per, x to y' is 18500, over y' you get the full 20k.
A 2nd enforced here in WA st, not in Illinois per past comments from wadcutter, is lbs per inch width of tire. Minimum is 500 lbs per inch. A state can allow more. BUT you pull across a state line that goes with a lower amount, you get taxed/fined for being overwieght. Here if unit has duals, you get 600, singles 500 per inch.I have heard of the width limit enforced for a long time. OTOH, law requires the load rating on sidewalls. I bet it would be a rare tire that was not wide enough to handle the rating. But this is a place where many RVers that have no idea what their rig weighs could get in trouble.
Aug-30-2022 06:25 AM
Aug-30-2022 06:24 AM
Aug-30-2022 06:00 AM
Aug-30-2022 04:09 AM
Wadcutter wrote:
That's correct. You posted it correctly. Not overweight. Over Licensed Gross Weight. Your "Licensed" weight.
They can use whatever fine schedule that state decides to use.
It's what I said initially. A person has to learn the difference. Licensed weight is what you pay in licensing fee to haul whatever weight you want to haul.
I taught truck weight law for a lot of years. I even attempted to teach it to truckers.
Aug-29-2022 07:48 PM
Aug-29-2022 04:55 PM
mkirsch wrote:
Oh I don't doubt that a "CVEO" said at least SOME if not ALL of the things being attributed to them. Even CVEOs are not all 100% up on the law or what it applies to.
JRscooby wrote:
Well, if I use a tandem dump mostly to haul dirt and rough haul, and don't want to get into the heavy vehicle tax, I license it for 54,000 lbs. Most loads will be well under 16 tons, so I'm in good shape. OTOH, if I decide to load 20 ton of gravel, get caught, I can tell you exactly what it will say on the ticket(s) 1 will say I was OVER licensed Gross WEIGHT by (roughly 7000) lbs. And when I call the court, give them the ticket number, the will read the same formula as what the charge is for over axle or tandem weight. (That works out to $635.00 for 7000 lbs)
Aug-29-2022 01:28 PM
Aug-29-2022 12:07 PM
Aug-29-2022 08:43 AM
Aug-29-2022 07:52 AM
blt2ski wrote:Me Again wrote:
I will bet that there are gazillions of trailers in the 1500 lbs states running around without brakes. If hardly any manufacture puts brake on trailers under 3K, NONE would put brakes on a 1500 pound rated trailer.
Chris,
That would be a good bet to a point.....if you and I bought said NEW 3500 lb trailer in a state requiring brakes on a 1000 lb or greater trailer. If we got into an accident, or some other issue that is our fault, trailer lacking breaks when sold new, that would, could, should open up the dealer from a potential liability standpoint. Used from a non dealer would be a different issue.
I would think, if the trailer manufacture did not make the trailer to meet local jurisdiction standards, the dealer would have to install the appropriate parts before selling us the trailers. As they would should have to certify said trailer meets local jurisdiction guidelines for said trailer.
Back to earlier point re the Texas manufacture. When I first looked at that brand, they did not offer brakes on both axles, later they offered manufacture installed brakes on both axles for $X more to meet local specs with this in mind, I would think that the manufacture would offer brakes installed to meet local guidelines, so niether they, or dealer has liability issues.
Marty
Aug-28-2022 06:25 PM
Aug-28-2022 03:01 PM
