โSep-10-2016 10:08 PM
โSep-17-2016 10:21 PM
montecarlo31 wrote:ROBERTSUNRUS wrote:
๐ Hi, your Expedition is close to what my Navigator is. My Navigator has a payload of 1,600 lbs. and a tow rating of 8,900 lbs. My trailer has a GVWR of 6,300 lbs and an actual tongue weight of 900 lbs. This leaves about 700 lbs for me and my wife and some other stuff in my Lincoln. Also a 35' trailer is 10 feet longer than mine and will become a big sail when the wind hits it. My opinion is to have a trailer close to 25' and no more than 7,000 lbs. for your tow vehicle.
Another way to figure it out is to figure the tongue weight of a maxed out trailer and start deducting everything from your payload rating.
Wait so you are giving him advise as a 2000 navigator owner? You realize there have been two major overhauls since yours right? You realize his wheelbase is 12" longer than yours? You realize his curb weight (ability to control the towed load) is significantly higher? You realize the CG is lower? Please re-read and then maybe give some advise that is more applicable like my truck isn't anything like yours but I'll go ahead and give you some advise anyway.
โSep-17-2016 04:04 PM
โSep-17-2016 11:34 AM
โSep-13-2016 05:49 AM
โSep-13-2016 01:22 AM
โSep-12-2016 11:19 AM
โSep-12-2016 08:56 AM
โSep-12-2016 08:20 AM
Tycho wrote:
We are noobs to buying and owning TTs but we are learning. What continues to confuse us is the advice/research into what exactly is our max trailer capacity for pulling. What size trailer can we get. If I read the black and white numbers then it looks really good for us. But when I do deeper research including older posts on this board, I get really confused as I am not sure what we truly can and can't do.
Here is what we have for a TV:
2012 Expedition EL Limited (5.4L V8 and 3.73 Axel) with HD towing package (Trans cooler, Trailer brakes, class IV hitch).
The numbers Ford gives:
GCWR 15,000#s
Max Trailer size of 8,700#s.
Max tongue load of 890#s
Other numbers I have found:
Curb Weight: 5781#s
Maximum payload:1590#s
As an example TT, here are the specs on one we like the most so far.
UVW 5638#s
GVWR 7600#s
CCC 1962#s
Hitch Weight 639#s
Full length 33'5"
On the surface we look fine and should be able to pull it considering we are 1100#s under the max rating for our TV.
But if I do the math (I believe correctly...)
Curb weight + Max Payload + Trailer GVWR + Hitch Weight = 15,610#s
This means my GCW is over the GCWR rating if I was to fully load the TT and TV down. Does this then mean that I should avoid the TT and look for something smaller? Or since this is the extreme high end that I am ok?
The other concern I have is the tongue. If I again do the math, according to Ford I should be 10-15% of loaded trailer weight.
So calculating that it would be 760(10%)- 1140#s(15%). It will obviously exceed the rating of the tongue then at about 11%. So how do I interpret this? If I would go by the percents then I would be looking for a TT under 6000#s to accommodate the 15%. Why does the vehicle even get a 8700# rating. Confusing....
Are there other concerns I may be overlooking? Perhaps I missed something in my calculations and it is better than it looks?
โSep-12-2016 04:09 AM
โSep-12-2016 02:04 AM
Gdetrailer wrote:
Personally, I do not subscribe to the general consensus around most RV forums of going big or go home..
I call it the "super size" mentality where most folks think just because a vehicle is rated at a certain level that they MUST buy a trailer AT that level..
I would rather UNDER SIZE my trailer for the vehicle!
For instance, 2013 F250 with 3415 lbs of cargo.. 26ft TT loaded I am at 7K lbs.. Well below my vehicles capacity in all aspects..
Gives me plenty of leftover capacity just in case MR MURPHY crosses my path..
I can tell you, it HAS payed dividends a few times.. I have dodged DEER running across in front of me not once but TWICE over the years.. And at HIGHWAY SPEEDS!! One time was so close I could see the deer ticks JUMPING off the deer :E
MR MURPHY stinks but I beat him at his game :B
Had I had a lighter vehicle and heavier trailer, the outcome most likely would not have been good.
โSep-11-2016 06:21 PM
Tycho wrote:
Boy this stuff is almost bad as common core math!
Looking at that 1385#s minus my families weight puts the number down in the 1000 range. Throw possibilities of cargo around 200 pounds and we are talking 800 range. Though I would think most of my cargo would be in the TT and not the Expy?
In any case that max number is looking lower than the max tongue load of 890#s.
I checked the hitch sticker and it can support the WD hitch which then says max tongue is 920 on the sticker.Gdetrailer wrote:
Buying by using DRY or EMPTY weights without figuring in ALL the "stuff" you load into the trailer will often put you into a potential overload situation..
In our shopping I definitely have been looking at the max trailer weights not the dry. My rule of thumb has been looking at somewhere around 7500 or below. But as I read more online I have become more confused about what is going to be good for us. Some say it is too much TT for the TV, others have success stories of pulling TTs bigger for multiple years without issue.
Also another question, how much does a load leveling suspension help? My Expy has one when we bought it and am not sure how helpful it is.
Thanks again for everyone's comments and helpful suggestions!
โSep-11-2016 05:37 PM
โSep-11-2016 05:00 PM
โSep-11-2016 03:18 PM
Tycho wrote:APT wrote:
Your Expy is likely limited by either the as equipped payload or the recevier rating of 890 pounds. Check the driver's door sticker for max combined weight of occupants and cargo shall not exceed weight.
Sticker says shall not exceed 1385#s. How is that number different than max payload number I found or is it the same and the door is just the more accurate number?
