V10 or 7.3 power vs tundra 5.7
woody0331
So I've known for a long time that I'm riding heavy. I'm now in a better position to try and correct this. I currently have an 08 tundra 5.7 pullin a Dutchman rubicon 1905TH. (19' box, 25' tounge to bumper) Factory weight just around 5800 lbs so some where around 7-8k lbs. (Our toys are 2 bikes or 2 kayaks, no atvs). Factory tounge weight of 810lbs? So realistically actual tounge weight of 1k. We live in denver and our trips consist of just on the other side of the Eisenhower with a few 3-4 hr extended weekend trips into the mountains.
I'm considering an early 2000s v10 or 7.3 for their durability and longevity. But after looking in to the the power on the v10 and 7.3, they are not that much better and I would be dropping from a 6speed to a 4.
My tundra pulls the trailer ok up the the "Ike challenge course". Most of it I put it into 2nd gear, hold 4-4.2k rpm which yields 45mph.
How would the v10 or 7.3 compare in performance.
Keep in mind, I know the truck handling and suspension will be better in a 250/350 I'm more concerned with pulling.
51 REPLIES 51
woody0331
I agree with the cummins 5.9 suggestions, but those are impossible to find inexpensive without over 200k miles. The 2005 and up v10s are also holding there value as well.
DW and I are thinking of buying a "simple" bare bones or inexpensive camper hauler/second vehicle while putting more money into a family car/daily driver/ winter ski vehicle. Or I'd be looking at these newer trucks out there.
A lot of good suggestions I've recieved already. Thanks everybody.
mudfuel07
I would either look at the 7.3 or a 08-10 V10. Depends if you like the gas station or not. The 3 valve V10's had good power but could be thirsty. I would choose either of those over a Maxipad or Cumapart anyday!
2020 Ram 2500 6.7 CTD 4x4 Tradesman(with a few toys)
2020 Puma by Palomino 32RBFQ for the kids!
FishOnOne
rhagfo wrote:
N-Trouble wrote:
Save up a few more pennies and pick up an early 200x Duramax or 5.9 Cummins. I don't think you would be to happy with either of your two current choices.
X2!!!!
If you are considering diesel look at all three, you can find a Dmax or Cummins in newer years that will knock your socks off.
why people think Ford is the only way to go is crazy.
Loyal Ford owner for 43 years, I chose to go with the Ram/Cummins for a Diesel. Never looked back.
Yes my Cummins has 280,000+ miles and is still towing strong, that is the beauty of a diesel.
I thought the same so we gave a 5.9 cummins RAM a try for our farm/ranch use. After constant phone calls of needing to foot the bill for a repair I finally decided to cut my losses and purchase another 7.3 PSD Super Duty. And this is from a long time GM owner.
BTW... My wallet is a witness to the above. :M
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
John___Angela
Powerdude wrote:
valhalla360 wrote:
Isn't the top of that pass around 11,000ft. With a naturally aspirated engine you lose something like 3-4% per 1000ft above sea level, so your current truck is probably putting out the power of a smart car near the top..
Now that's some funny stuff. :B
SmartCar 2014 is 70 hp.
The gassers are 70 HP. My diesel smart car is 44 HP. More torque though. 🙂
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
rhagfo
X2!!!!
N-Trouble
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
Kevin_O_
If you want the V10 look at a 2005 and newer. They made 362hp/457tq
KEVIN :C
DW-Debbie :R
DS-Tyler 11yrs old:D
DD-Makayla 8yrs old:p
MERIDEN,CT
2001 Ford Powerstroke F350 Lariat
2012 Keystone Outback 292BH-OLD
2016 Jayco 29.5BHDS-NEW
Kevin_O_
spadoctor wrote:
In 2000 the HP and torque of the V10 were higher then the 7.3....but you need to let it rev.
It made more Hp not torque. From 2000-2004 the V10 made 310hp/ 425tq. The 7.3L made 235hp/500tq. The key factor is the turbo diesel really wouldn't be affected with the high elevation like the naturally aspirated V10 would...
KEVIN :C
DW-Debbie :R
MERIDEN,CT
Golden_HVAC
Don't look at to early of a 7.3L, back in the early 90's they where not turbocharged.
I would pick the V10 if you are just using it to pull the trailer, and not putting more than 5,000 miles a year on the truck.
The oil changes are much more reasonable, and the truck overall is much lighter. Unless you are planning on finding a dually. The crewcab F-250 4X4 only had a 865 pound weight rating with the 7.3L engine in it! GVWR was only 8,800 pounds while the curb weight is nearly 8,000 pounds! The F-350 has only marginally more capacity, at 9,900 GVWR until MY 2004. In 2005, the GVWR of a SRW F-350 went up to 11,000 pounds for the gas engine and 11,500 pounds for the un-desirable 6L diesel engines.
So if you are looking for the V10, check out MY 2001 and later, with 2005 being the 'heavy duty' version with a LOT higher cargo rating. The F-250 in 2005 and later has a 10,000 GVWR, while 2004 and earlier is only 8,800 pounds. Gas engine is about 700 pounds less than the diesel.
GOod luck!
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
fla-gypsy
A 2005 or later Ford F-250 6.8L V-10 (5sp) would make a nice improvement over your 2008 5.7L.
12thgenusa
You need to let it go to third gear. I've pulled my 5er (8400 GVW) many times over that stretch of road at 60 mph, 3800 rpm. Coming up from the east side is a little slower since the road is a little more twisty on that side.
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar, Victron BMV-712, Victron SmartSolar 100/30, 200AH LiP04 bank, ProWatt 2000.
spadoctor
Ivylog
Try to find a 7.3 with a six speed manual transmission in the later years with 275 hp. The warm-up butterfly can be tricked into a very good exhaust brake. Makes for a great truck.
Upgraded with a 08 HR Navigator 45’...
jerem0621
Sounds good, If your over then its time to think about upgrading. IMHO... I'd skip the V10 and go for the 7.3.
Not that the V10 is a bad motor..its great. I just think the 7.3 is better in your case with high elevation. I would skip 6.0's or 6.4's and stick to the 7.3.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
It’s Kind of Fun to do the Impossible
~Walt Disney~
woody0331
Thanks for the vote of confidence. I figured a turbo would help. I'm not looking at going much faster up the hill. Holding 55 comfortably would be nice. I just don't want to be going slower with an "upgrade" in trucks.
The 2 less gears and lower hp on paper really threw me off.
@ jerrimiah. I do like my tundra but my camper is real tounge heavy. I keep my payload as low as possible in the truck but I think I'm either over or don't have much room to spare. Either way, the bed is not really useful when towing. And I feel the truck is a little too squishy.
