Weight of travel trailer
egh33
What is the ideal weight of a travel trailer you can pull with a F-150 4x4 Ford with towing package??
28 REPLIES 28
goducks10
I wouldn't go over 7,000 lbs loaded regardless of power train. The truck it's self is light in weight due to the aluminum body. You want as much weight towing the TT as you can get for stability.
Just because you can go 60 mph vs 50 mph up a hill won't mean diddle in side winds or passing or being passed by semi's.
Atlee
Ideally, if you could find another unicorn like I have, you'd be good. 3.5L EB, 3.73 rear, 6sp xmission, 2,286# cargo capacity, 4800# rear axle.
Mine came with Max Tow and HD Package.
Erroll, Mary
2021 Coachmen Freedom Express 20SE
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
Equal-i-zer Hitch
Terryallan
Honestly we can't tell you with out knowing which F150 you have. Ford make about 20 variations of the F150. some with 6clys, some with turbos, some with out, V8s. some with low rear gears, and some with high rear gears, and the truth is you can get the towing package in all of them.
Best thing to do is find out which one you have. which engine, which rear gear, what trim package, and so on. and of course what GVWR you have. That will determine how much tongue weight you can carry. and so determine how heave the TT can be.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
philh
1/2 Ton trucks like the F150 will often run out of payload long before tow capacity.
Lwiddis
I don't like towing more than 6,000 pounds with my 1500 or the Tahoe before it. Well within specifications.
What are your truck's limits from the Ford door sticker?
Grit_dog
Navigator
Navigator
valhalla360 wrote:
dodge guy wrote:
I wouldnโ€™t go any higher than 7k lbs loaded.
A lot of 1/2 tons shouldn't be towing 4-5k.
Others may be able to handle upwards of 10k.
Depends on the specs of the truck. They vary wildly for 1/2 ton trucks.
Lol, unless you're including old wore out, less than OE capability, or an old 6 cyl 3 on the tree with 3.07 gears, there isn't a 1/2 ton built for idk how many years that isn't rated at least 5klbs and 99% of them are rated higher than that.
aftermath
I agree with what Nickthehunter just said. A tow rating is a decent place to start but....few half tons can actually tow the maximum weight stated without having troubles in other areas. I tow a 6500 lb trailer with my Tundra that (they say) can tow 10K lbs. With a TW of close to 1000 lbs I am close to my payload number before I even start the engine. So, look at axle ratings and payload capacities when you start to narrow your choices.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
nickthehunter
Nomad II
Nomad II
There are two stickers on the door of the truck. They give you information like GVWR, RAWR, max cargo (payload), that the info anyone would to tell you what you can reasonably tow. Without that info, any answers to your question have no basis in facts.
valhalla360
Nomad III
Nomad III
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
APT
6k dry, assuming you have the HD towing package and either 3.5L Ecoboost or 5.0L V8 engines. Lots of power, but suspension and stability on the highway are the more practical limitations.
2017 Subaru Outback 3.6R
dodge_guy
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Sagebrush
Much less than they say IMO. The year of the truck makes a huge difference. Do you have a 2001 or a 2021? Look up the towing guide and see what your weights are for your actual truck. Then go way under the max figures if you want to enjoy traveling.
When I towed with the older F150 size trucks I preferred trailers around 6K and 25' max and the biggest engine option. I used the equalizer brand hitch set up. Trucks are rated for more GCWR now days. I learned right away I wanted a long wheel base truck with more weight though, never really liked pulling close to max with any size truck.
Skipg
Get your VIN # and call Ford give then the # and theyโ€™ll tell what your truck is rated to tow. My 2020 F150 with max tow package is rated to tow 13200 lbs
JIMNLIN
Depends on the F150 gvwr rawr....engine size/tranny a drive ratio.
Ford gives the F150 gvwrs ranging from tiny 6200 lbs up to 8200 lbs and rawr from very small 3200 lbs up to 4800 lbs. And of course engine sizes from small v6 up to the 5.0....3.5 EB engines.
