Feb-02-2015 11:55 AM
Feb-04-2015 03:39 AM
My first 1/2 ton towing trailers was a '67 chevy with a 5600 GVWR 3.73 axle 135 hp 283 v8 two barrel carb with the two speed powerglide tranny. Sure it was slow but it was what it was and I expected that. I mounted a 8' TC on the truck and pulled a 16' 2800 lb fishing boat. Lots of good memories traveling the southern Rockies back then with the kids.
Feb-04-2015 02:46 AM
Feb-04-2015 01:17 AM
Dreenn wrote:Don't load the rear too much. You may take off too much tongue weight which will increase sway.
Thanks a lot for your input I have a standard tonnou so not much weight there as for coolers and such I'll prolly put those in the back of the Tt on the bottom bunk to save on tongue weight and bikes the guy I bought it from has a bike holder on the rear of the Tt that is bolted to a plate that's welded on the bumper support the thing is solid
Feb-03-2015 09:56 PM
rbpru wrote:
Interesting tire test. It has been a long time since I needed to run my rig though a slalom course.
However it has not been too long since I had to swerve hard to avoid a side swipe while merging on to the interstate. I had absolutely no sway, rebound or any other problem. All this was with those evil "P" and "ST" type tires.
And no. I do not want to repeat it to see what happens.
Feb-03-2015 08:13 PM
Need-A-Vacation wrote:
While there are plenty of trailers that a 1500/150 can tow within all the tv's ratings, the biggest issue is after the trailer is all loaded up, new trailer owners go and fill the bed full of heavy coolers, firewood, strap the bikes down on top in the bed, and off they drive.
The newer GM Twins (since '14) do have more payload than the previous gen trucks, and those along with the Ford trucks are really the best choice (when equipped to tow!!!) for a larger trailer. Ram just doesn't seem to have the needed payload for larger trailers without exceeding the ratings. Motor wise, all three can pull plenty (talking 5.3/6.2/5.0/Ecoboost/5.7/6.4) with the right set of gears.
Patiently waiting for a reply about the manufactures designing the trucks (is this all vehicles?) for 1.5x the ratings. I could believe maybe a 10% margin, but 1.5x???
Dreenn,
Watch what is loaded in the truck, and you will probably be ok pending you don't add a cab high topper, or other heavy accessories that will eat the payload up. As mentioned, it all adds up very quickly!
Feb-03-2015 07:37 PM
Feb-03-2015 07:33 PM
Feb-03-2015 07:06 PM
RinconVTR wrote:CKNSLS wrote:mb1776 wrote:
These weight discussions are exhausting...being a newbie the issue of weight is very confusing. The manufacture tells you one thing to sell the truck. The RV dealer tells you another to sell the trailer. The only absolutes in this discussion seem to be 1) your tv has a weight limit developed with safety in mind. 2) your TT also has a weight limit so that it can be operated safely. 3) whether you, as the owner of both the tv and tt, choose to go inside or outside those limits is entirely up to you. For myself, having tried to tow my 6600 lbs TT with a 1/2 ton a few times, I decided I would be more comfortable stepping up to a 3/4 ton. I know I will be safely inside the parameters on both the tv and tt. Having that peace of mind with a wife and two small children riding along is worth it to me.
Are you really safer?
Exactly. Lets stop assuming bigger is better in all cases...AND that bigger = safer. That is a false belief, as false as they come.
Feb-03-2015 06:51 PM
Feb-03-2015 06:46 PM
op wrote:
Why all the hate on 1/2 ton tvs
Feb-03-2015 06:28 PM
Feb-03-2015 06:27 PM
Feb-03-2015 06:19 PM
Clicky
I don't think the weight and stability of the dually was a disadvantage vs.something smaller
Feb-03-2015 06:11 PM
Clicky
Feb-03-2015 05:23 PM
