โMay-04-2018 05:43 PM
โMay-06-2018 04:50 PM
2112 wrote:
You're making this too hard on yourself. Plus you do not know the load demand of any 12VDC branch you tie into. You could be setting yourself up for blowing fuses.
The air conditioner black wire is connected to a breaker on the A/C side of your power distribution panel. The breaker should be identified as AC on the panel label. The white wire and bare ground wire are connected to the common and ground bars.
Assure camper is unplugged from power and battery is disconnected. Disconnect the three wires identified above and pull out from the back side of your distribution panel. With masking tape and permanent marker, fold the bare wire back and secure with tape. On the tape identify this end as "moved from air conditioner to DC MaxFlo fan". Move the wires to the DC side of the panel. Now you need to select a fuse if an empty one is not available. I suggest the furnace. You most likely will not run the furnace and this new fan at the same time. Connect the white wire to the furnace connection. Connect the black wire to the large lug identified as "BATT -".
On the fan side fold the bare wire back, wrap with masking tape and write "From AC Wiring". Connect the fan red wire to existing white wire and the fan black wire to the existing black wire and install the fan.
Put it all back together, connect to shore power and/or battery. Your new fan should work. Just remember you might blow the fuse if you run the fan and furnace blower at the same time. Have a spare fuse on hand.
โMay-06-2018 01:40 PM
โMay-06-2018 07:22 AM
โMay-06-2018 06:29 AM
SoundGuy wrote:As I said, if it were me I'd just pull +/- 12 vdc from a nearby overhead light and be done with it ... now that's "simple". ๐daboognish88 wrote:
Yea I decided I'm just going to leave the original AC wire alone in case I or someone else ever wants to reinstall AC.
I've tried going from a nearby light but the wire must be damaged somewhere along the line.SoundGuy wrote:
That makes no sense - if the light works there has to be +/- 12 vdc at the light so just tap off that source.drsteve wrote:
It's probably a switched circuit...
So turn the switch on and control the light itself with it's own switch, if doesn't have a switch then replace it with one that does.
โMay-06-2018 06:24 AM
โMay-06-2018 06:16 AM
daboognish88 wrote:
I got rid of the rotten old AC unit and want to replace it with a Maxxair. Problem is I don't know how to wire it.
Do I have to run all new wire to the battery (or wherever it runs to) or can I use the same wire but convert it somehow to connect to the Maxxair? I suspect it will be hard to run new wire through this ceiling.
The existing wire from the AC says its
12/2 WG, 600 V, (UL), ETTCOFLEX, TYPE NM
I think the AC only ever ran on shore power. So I'm not sure if this will even connect to the RV marine battery.
Any tips?
Thanks.
โMay-06-2018 05:49 AM
โMay-06-2018 05:36 AM
โMay-06-2018 04:40 AM
daboognish88 wrote:As I said, if it were me I'd just pull +/- 12 vdc from a nearby overhead light and be done with it ... now that's "simple". ๐
I've tried going from a nearby light but the wire must be damaged somewhere along the line. So I tried to go from an further small wall mounted fan wire but that didn't work either. So yea a lot of these wires seem to be dead. So I guess I have to run new wires after all. I don't know how I'm going to do that because they make it impossible to run new wire. I'm guessing everything was wired up before they put on all of the inside panels and such. :R
โMay-05-2018 10:51 PM
โMay-05-2018 08:04 AM
SidecarFlip wrote:
The wire is already there, just use it for the intended purpose, intent is 12 volts this time. I think you guys are over complicating an easy task.
โMay-05-2018 06:10 AM
SidecarFlip wrote:
Why wouldn't the 120V solid copper wire that supplied the defunct ac unit work for powering the Maxair fan? The wire don't know if it's 12 volts dc in it or 120 volts ac.
I'd trace the wire back to the power source, disconnect it and reconnect it to a 12 volt source to power the fan, Simple and issue solved. Use the existing wire.
โMay-05-2018 06:00 AM
โMay-05-2018 05:41 AM
SoundGuy wrote:christopherglenn wrote:
And make sure you flag the wires as 12 volt only - so the next guy doesn't set something on fire by putting them back into the 120 volt breaker.
Ac wiring black is hot, white is neutral (ground). DC wiring black is ground red is hot (+12). In this case I would use the white as a +12.
And therein lies the rub ... Romex used to feed 120 vac would normally be colour coded black & white with a separate ground wire, black being hot and white being neutral. If converting use of this cable for feeding 12 vdc I'd do just the opposite you're suggesting and use black for + 12 volts and white for - 12 volts. To avoid any confusion later on the solution is to label each wire at both ends. All that said, I personally wouldn't convert a 120 vac cable for 12 vdc use and would instead just pull +/- 12 vdc from a nearby overhead light.
โMay-05-2018 04:31 AM
