โSep-06-2015 04:14 PM
โSep-08-2015 12:16 PM
myredracer wrote:
If someone is breaking them, there's always the chance of operator error too.
Unplugging from the outlet.
1) Ensure that you are wearing rubber sole shoes and are not standing on a wet surface.
2) Place the rubber insulating glove on your non/dominant hand.
3) Grasp the plug, being careful to not shake or move it.
4) With the insulated glove, cup the plug creating an opposing force all around the the plug.Pull the plug out.
NOTE: In order to not break the outlet you must exert the same force with the cupped hand that you use for pulling. Too much force on the cupped hand will cause the outlet plate to flex and break. Not enough force will cause the outlet plate to flex and break.
If you do not have the special insulating gloves (not supplied with device) then you must turn off the breaker for the outlet you intend to unplug from and ensure there is no power to the outlet.
Plugging into the outlet:
1) Turn breaker off to outlet
2) Remove device from wall. There are two screws, cross your fingers that the installer left the recommended 12" service loop.
3) Place you hand behind device (for extra safety use the removal insulating glove)
4) Insert plug, ensuring the device is supported on the opposite side. Avoid applying pressure to the mounting plate.
5) Screw outlet back into wall
6) Turn breaker on
Due to the fantastic design of these units you risk electrical shock and possibly death if you do not follow these instructions.
โSep-08-2015 11:34 AM
โSep-08-2015 08:32 AM
Bobbo wrote:myredracer wrote:
Info. on the Hubbel Wirecon SCD is here.
Your link pulls up a picture of a jack stand.
โSep-08-2015 07:29 AM
โSep-08-2015 06:48 AM
โSep-08-2015 03:09 AM
โSep-07-2015 05:10 PM
โSep-07-2015 09:46 AM
christopherglenn wrote:
No, they are RV outlets. Most (all?) home depot outlets are intended to be put in a box, RV outlets are direct wired, and have covers - covering the wires and connections. They are also designed to be mounted directly to the wall covering. Stick and brick outlets screw top and bottom into the mounting box.
Pull one before going to the store and look at it. I have never seen them at HD / Lowes / ACE / Orchard Supply / ETC..
โSep-07-2015 08:04 AM
โSep-06-2015 05:40 PM
โSep-06-2015 05:34 PM
โSep-06-2015 04:47 PM
โSep-06-2015 04:28 PM
