Anyone modify their air bag pump for other use?
MartyMoose
Getting ready to add airbags to my F250 and I'm debating going with an onboard compressor.
Has anyone modified this so it could also be used as a tire pump for their "toys" and other?
Thanks
2014 Heartland 305RW Road Warrior
2012 Ford F250 Lariat
12 REPLIES 12
Crazy_Cooter
I have been thinking of split mounting one of these under the truck with possibly a larger tank? http://www.ebay.com/itm/PUMA-12-VOLT-1-5-GALLON-OIL-LESS-AIR-COMPRESSOR-FREE-SHIPPING-/280790586347?pt=LH_DefaultDomain_0&hash=item41606c53eb
1999 Peterbilt 385
2006 Dodge Ram 3500 DRW
1992 Jeep Wrangler YJ
2010 NuWa Hitchhiker 36LKRSB
2012 Cyclone 300C Triple Axle
2013 Can Am Maverick X-RS
2006 KTM 525 EXC CA Plated
rcpd34
Here is the write up I did for 8 Lug HD Truck magazine on the air bag/sway bar install:
http://www.8-lug.com/tech/1101_8l_2008_chevy_silverado_2500hd_buildup/
System works great. The auto level can't be beat and I use the tank for filling tire without issue. I tried running some air tools, but it wouldn't keep up. I also have a Warn winch with compressor on the front (different article) and with a 10 gal tank, that runs the tools just fine.
Brian
2014 Dutchmen Voltage V300
2008 Chevy Silverado 2500HD CC/SB 4X4 Duramax LMM/LTZ/Z71
2500_Grunt
Thanks
Tire pump from 60 to 80 psi, blow off tool while at the dunes, train horns, air bag pump, bicycle, quad, motorcycle pump and for my future exhaust brake.
2005 Dodge 2500 5.9 SRW long bed
2014 FS28 Evergreen Amped TH Blue Ox 2000# WDH
2300CC VW turbo 4 seat sandrail, Yz450f, 350 Raptor quad
pronstar
Compressor and tank for airbags, exhaust brake and on-board air.
OBA is for when you're out and about and need to air-up a tire, or whatever else you need air for...it's not really a substitute for a full-size compressor.
'07 Ram 5.9 QC/LB SRW
Full Carli Suspension
35" Toyo's | 4.56 | PacBrake
2009 Cyclone 3950 | B&W Turnover Ball & Companion | TrailAire | Duravis R250s
Macman83
I put an airbag setup on my old truck with an onboard compressor. The compressor worked great for the bags, but it would be awfully slow for filling anything else. You would definitely need a good sized reservoir tank to go with it. I bought a used 110 volt 3 gallon pancake compressor that fits in the front compartment from a pawn shop, and I use it for everything.
2010 Ford F450 Superduty diesel
2013 Voltage 3905
my996duc1
I run a quick connect on both sides under the doors.
I also run a Shocker air horn wired into the upfitter (Ford) switches so I can use the regular horn or use the regular horn button for the air horns.
Works great for when needed as most people ignore regular car/truck horns..... you can't ignore the Shocker air horns ๐Ÿ™‚
_
2007 Coachmen Cross Country 354MBS
2005 LJ Rubicon Sahara
MartyMoose
Thanks for the tips. I thought this was more popular of a mod. I was kicking over getting a onboard pump and though this option would help justify it.
My F250 doesn't sag that much when I hitch up so I only see using bags on my longer trips. I'll save the bucks and work out my biceps...:)
sin_cal_hd
This is the best one I have found. But I dont own.
they used to have prices. They were not cheap 12 years ago.
2015 2500 Ram Mega Cab 4x4
2017 Wolf pack 325
Wife and 2 little boys
2 golden retriever pups
mustangglp
You might want to buy the compressor sperate that way you can add a bigger one.
Gary
Arch_Stanton
The kit I bought came with the Tee and self-coiling line to inflate a tire or small stuff. The air bag compressors are not what you'd call HD stuff, they will deliver the pressure to inflate your air bags but I would not want to regularly cycle mine to inflate a full size tire or even a ATV tire. Emergency? In a heartbeat and glad I set it up that way.
2007 Dodge Ram 3500 Quad cab 4x4 dually, 5.9 Cummins, 6-speed manual, Jakobs Exhaust Brake, Air Bags, trans coolers, Redline in everything.
Towing a 2014 Eclipse Attitude 32AKLG 5'er on a B&W Turnover Ball 5'er Hitch
sin_cal_hd
I have. Off my tank i ran 3/8 line and put 1 quick connect on either side of my truck under the rear doors. I have about a 5 gallons tank under my driver door inside the frame rails. I also run a 152db air horn. Just for fun.
2017 Wolf pack 325
Sprink-Fitter
Thanks
I thought about doing that but our toy hauler has an on board air compressor, if it didn't I think I would though.
2006 Coachman Adrenaline 228FB
2012 Can Am Commander XT 1000
