โApr-17-2015 08:02 PM
โApr-19-2015 04:45 AM
โApr-18-2015 10:07 PM
Goostoff wrote:I carry a stick that I use to mark the height of the camper when I unhook, and then use that mark to lower or raise the camper to hook back up. This method gets within a 1/2 inch 90% of the time. The other 10% is due to the TV location being changed. I also use that stick and a small level to pre-level the location with blocks if the site is unlevel.
Practice makes perfect. I just line up the dually fendes even in both side mirrors. I alway make sure to stop a few inches before contact Ind get out to check just to be certain I have the trailer height correct. Then just back under slowly until it latches. ๐
โApr-18-2015 09:47 PM
โApr-18-2015 05:27 PM
โApr-18-2015 02:31 PM
โApr-18-2015 01:49 PM
CarnationSailor wrote:N-Trouble wrote:
OP never even says what kind of hitch he's running...
I have same truck and unless he's 4ft tall or using a GN adapter am not following how he can't see the hitch out the back window. I can see mine plain as day and it's in the lowest position.
Lots of good recommendations here but let's figure out what's REALLY going on.
Where does the arrogance come from with people like this that assume they know better than the OP?
Probably not worthy of a response, but I'll try to provide "what's REALLY going on".
I'm 5' 10' tall and the hitch is a Demco Hijacker Auto Slide mounted in the lowest position. (And no, it is not mounted too far forward.) I had a friend place a tape measure on top of the hitch and the lowest mark I can see is the 5-inch mark. So the hitch would probably have to be 6 inches higher for me to see it when hitching up.
On a more positive note, thanks to all who contributed useful suggestions. I'm sure I can develop my own method from the inputs received.
โApr-18-2015 01:06 PM
โApr-18-2015 09:32 AM
โApr-18-2015 08:58 AM
โApr-18-2015 08:40 AM
โApr-18-2015 08:18 AM
handye9 wrote:
Saw this on ebay.
โApr-18-2015 08:15 AM
โApr-18-2015 08:14 AM
โApr-18-2015 07:47 AM
โApr-18-2015 07:26 AM
