Nov-04-2019 02:29 PM
Jun-13-2024 09:17 PM - edited Jun-13-2024 10:14 PM
I know my post is years later, but I took it apart. I'm hoping someone knows where I can buy the clevis pin that goes on top that has the cotter pin, that's all that's wrong with mine.
My control panel failed last summer and I used a drill to lift and drop the gear manually, so I assume I used a little more torque than I should have when I raised it all the way up. I have the GC 3.0 system and it's my D/S rear gear that snapped.
According to Lippert, they don't offer a service kit for this, which is ridiculous if you ask me. They want me to spend $450 for a new one. Surely I can source the cotter pin that goes through, even from a different manufacturer? I would be very grateful if anyone else has figured this out. I'm not sure on the exact length as it snapped, but I would say it's about 1-1/8" (total length) and 5/16" wide.
Jun-14-2024 12:02 PM - edited Jun-14-2024 12:08 PM
Unless I’m misunderstanding your post, i searched for 5/16” Clevis pins on Amazon and got over 12 pages of results. (Your results may vary)
Jun-14-2024 12:46 PM
I was able to find one locally for a few bucks, put back together and voila! Beats $450! Have a good weekend!
Jun-19-2024 06:01 AM
did you happen to take picture of the internals so we can see what your talking about and to help others that might have this issue?
Nov-07-2019 10:40 AM
Nov-07-2019 05:53 AM
Hoppy220 wrote:
There is no way to get to it to lube it without complete disassembly. I run landing gear all the way out and spray gear lube through an opening in the outer housing hoping to get enough on the rod to help it out. It's just a bad design on liperts part.
Nov-07-2019 04:27 AM
Nov-06-2019 10:00 AM
Hoppy220 wrote:
There is a nut in the top of the leg that usually strips out due to lack of lubrication.
Nov-05-2019 05:29 PM
Nov-05-2019 12:43 PM
Nov-05-2019 11:25 AM
