How to lift each tire off the ground for service?
AMG1978
I have been using one of those yellow "Trailer Aid" devices to drive forward on (front axle) or reverse on (rear axle). It works, but I got to thinking, isn't there an easier way to get the job done safely? Does anyone know if it's save to jack up one side somehow? my floor jacks are only 2.5 ton, but if I had a many ton bottle jack or something, can you safely jack it up in place? Thanks.
If i did service unloaded (no toys or water) i'd still probably be at about 9500lbs.
2012 F-250 6.L Diesel 4x4 Lariat
2016 Forest River WA2916 35' Toy Hauler
34 REPLIES 34
AMG1978
I am OP and I will say that using my 3ton floor jack on the right "I" beam of the trailer, I was able to lift the right side of the trailer off the ground, i just went about 1/2" higher than needed and it worked great.
Thanks you all.
lincster
fj12ryder wrote:
lincster wrote:
fj12ryder wrote:
lincster wrote:
Never lift by the axle tubes.
I also have a 6 ton floor jack, so plenty of jack.
You wanna work on big boy stuff, you gotta have big boy equipment.
Pish tosh, I've jacked under the axle tube at the spring perches with no issues whatsoever. Changed tires, added suspension improvements, checked brakes/bearings, all without jacking the frame.
And a 6 ton jack is not "big boy stuff". I have a couple 12 tons, and a 20 ton. A 6 ton is what you use to jack up the axle.
Then welcome to the big boy club.
Do we need to compare other stuff now???
Is this where the "I'll show you mine if you show me yours" starts? :B
I'm not starting anything.
I was ending it.
Sorry to the OP.
Back on track.
2022 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
IdaD
Bottle jack on the spring perches. I did an axle flip so I have the older perches on the underside of the axle that make nice jacking points.
2015 Cummins Ram 4wd CC/SB
fj12ryder
Howard and Peggy
"Don't Panic"
N-Trouble
2112 wrote:
I lift one wheel at a time at the perch with a 2 ton floor jack. It's only lifting 25% of total weight minus hitch weight. For my setup that's ~2080lbs per wheel on my double axle.
A triple axle would be 16.66% of total weight minus hitch weight.
Wouldnโ€™t it be 50% of total - tongue? When you lift one wheel to raise the other off the ground your carrying the weight of both axles on that side.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
Ralph_Cramden
With a Jack.
Too many geezers, self appointed moderators, experts, and disappearing posts for me. Enjoy. How many times can the same thing be rehashed over and over?
racebug1098
:B
lincster
Lincsters Rail
lincster
1jeep wrote:
Why, please explain? I have jacked many up by putting the jack under the axle at the point where the ubolts meet the springs. I can understand not jacking mid point of the axle as this could cause the arch to be damaged.
Then u didnโ€™t truly lift by the axle tube did you?
If I need to explain more, let me know.
Lincsters Rail
AMG1978
Just lifted it fine by using the I beam and my floor jack with 2 spare 2x12x4โ€™
TAS1
I jack under the U-bolt on the axle. If I can't get under the U-bolt, I'll use wood next to the U-bolt to spread out the contact patch.
Todd
15 Ram Megacab 3500 4x4 SRW
18 Street Glide Special
13 Harley Fatboy Lo (gone)
94 Harley FLSTC
98 TJ w/ a few mods
18 Momentum 351M
fj12ryder
Howard and Peggy
"Don't Panic"
Old-Biscuit
Exactly...
RV MFG place warnings ---- lawyerese ---so that owners don't jack under axle bending it and then make claims etc
Trailer is attached to axles AT the suspension.
Lifting a wheel at spring perch on axle is no different then trailer going down road and BOUNCING UP/DOWN
Common sense but that is reason for the 'lawyerese'
1jeep
2016 Ford F350 crew cab dually 6.7 platinum with heavy tow and 4:30 gears
2015 Carbon 327 with a BMW k1600 and Canam 1k inside
lincster
I have huge tie blocks that my Dad gave me years ago, like as thick as railroad ties.
They get me the height I need to go up to the frame.
Then I have 6 ton jack stands to set the trailer one.
They go up high enough to keep the tires off the ground.
Lincsters Rail
