Maiden Voyage with new Voltage --- and Brake Issues
DR_Buck
Survived the weekend with the new Voltage toyhauler, despite my brake issues. I haven't completely confirmed it yet but it appears my high $$$ MAX BRAKE brake controller went belly up after 8 years.
After leaving home Friday evening at some point into the first 15 miles into my 50 mile trip the controller set the trailer brakes into a parking brake mode. I thought I was just having issues pulling up hill. Then a car pulled up next to me and yelled out the window that I had brake issues. So I pulled over the first chance I had to check. All 4 trailer wheels were hot and one had the brake drum glowing red! After messing with the controller and "Googling" the ownerโ€™s manual I was able to figure out it was in the parking brake mode and get it back to normal. Then I drove slowly to a large empty parking lot about 5 miles down the road where I got out and inspected things. The wheels were cooling down and the brakes seemed to work so I continued up over the mountain. I used low gear going down the back side and tried to minimize using the brakes after I noticed the controller indicating excess brake current. We made it to the campground at the bottom of the mountain and got set up OK.
Saturday morning I unloaded the Can Am Spyder (which I wasn't going to take on this 1st trip) and took a ride out to Lowes so I could buy a multimeter to troubleshoot the brake issue. After a nice 100 mile ride we got back to the campground near dinner time so the brake trouble shooting had to wait until Sunday morning because it was getting cold.
I spent a portion of Saturday night searching the web for tech info on my controller, trailer brake system, and wiring.
Fast forward to Sundayโ€ฆ. I hooked up the truck to the trailer and measured brake current and voltage. I kept getting intermittent and changing readings. I ended up tearing the dash out of my truck so I could get to the back of my controller to reset it. After resetting and calibrating the MAX BRAKE controller I was able to get consistent readings and with help of the multimeter I determined that one of the Voltageโ€™s electromagnets was shorted. I cut the power lead to that brake and the braking current came into line so we headed home.
Then part way down the mountain the brake controller started acting up and sometimes I had brakes on the trailer and sometimes I didn't. Fortunately we made it home without incident.
Later this week I'll hook the controller to one of my other trailers to see if it acts up. I may end up buying a new one just to be on the safe side anyway. I also need to pull all 4 wheels off the Voltage to assess the damage. Minimum I suspect I will need to replace brake shoes, electromagnets and at least one drum. Again, I may just replace them all to be safe.
2003 Ford F350 SRW 7.3L Diesel
Sumo Springs
Bilstein Shocks
2013 Dutchman Voltage 3200
2012 Can-Am Spyder RT Limited
27 REPLIES 27
DR_Buck
ksss wrote:
How do you like your Spyder? Dam those things are cool! I searched their website the other day. Which model do you have?
I love the Spyder. I hadn't ridden in close to 40 years and saw them advertised on TV and just had to have one. ๐Ÿ™‚ We got the RT Limited model. It's a 2012 model. I've had it just over a year and have spent a fortune on modifications and after market upgrades. ๐Ÿ™‚
Lots of information and pictures of them on Spyder Lovers Web Site
This link is pictures and descriptions of what I've done to mine. DR Buck's Spyder
Sumo Springs
Bilstein Shocks
ksss
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
DR_Buck
Finished changing all the brake assemblies. I went ahead and upgraded to self adjusters. All of the original brake pads and electro-magnets were fried! One of them came completly apart and destroyed the drum. Three of the drums were undamaged so I only had to replace the one bad one. I did replace all of the seals though just in case of heat damage.
I also got a new Maxx Brake controller that I will install later this week. I did try and contact Maxx Brake to ask questions about the failed unit but they did not answer my email or phone calls. If the old controller hadn't worked so well for 8 years I wouldn't have bought another Maxx Brake.
Sumo Springs
Bilstein Shocks
joebedford
Nomad II
Nomad II
I ran mine at 6 for quite a while, now 6.5 as the brakes have worn. I use the manual override if I have to make a quick stop. Trailer brakes are very effective but don't lock at speed.
BobWanderer
nayther wrote:
Bob and Randy what gain are you running your GMC integral controller at?
Usually 6 to 6.5 works well on the hwy.
If I do a lot of around town, I will turn it down.
2008 GMC 2500HD 4X4 DMAX CC
2004 Thor Wanderer Wagon 247WTB
2006 TE450 Husky
2007 Rhino Sport Edition
nayther
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
BoonHauler
Have you called the folks at MaxBrake to see what they have to say?
05 RAM 3500 CTD 4x4 Q/C Laramie DRW/NV5600/3.73, B&W Gooseneck, MaxBrake, PacBrake PRXB, Brite Box Fogster, BD steering Box Brace
2014 BoonHauler 3614
randyrees
BobWanderer wrote:
My 10K T H brakes work well enough to stop both the T V and T H, thats with stock brakes and factory GM controller. I reached over and pushed the controller lever to make sure the brakes were working and was very surprised at the outcome.
I have an Eclipes Attitude (loaded heavy with a SXS) that I pull with a GM Sierra and I had the same reaction as you the first time I tried the trailer brake controller...maybe it's because it's a GMC!!!!
R Rees
M-1028
Mmaxed wrote:
In my experience no electric brake will lock up the wheels on a heavy trailer on pavement when you are moving at a good clip.
Same here, I've pulled a LOT of different trailers. Only electric brakes that worked good where dexter 8K's with the big drums, far from locking up if the trailer was loaded.
Only brakes I've been around that will lock up tires on demand are electric over hydraulic, I can lock up all 6 on my toy hauler at 22K. Also had a 40 ft gooseneck that would put you through the windshield.
Every hot shot I know will not run electric brakes, so that says something
BobWanderer
2006 TE450 Husky
mapguy
If installed properly and adjusted properly they have the potential to skid at highway speeds.
Most systems are installed with minimal sized wiring and poor connections that compromise performance potential. Brake ajustment has a huge impact, too. Most people adjust electric trailer brakes like they did on their 1960's car/trucks -this is not nearly tight enough to operate properly -both speed and intensity, due to the way electric trailer brakes use magnet pull and inertia to energize.
64thunderbolt
My Rvision Bayhauler would lock them @ 75 mph @ was a little over 13K loaded.
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
DR_Buck
rrupert wrote:
This may be a long shot, but did you check the emergency breakaway switch to make sure it isn't messed up in some way?
Not possible. The Max Brake gives you a message on the screen that tells you what is happening. Mine had no display at all, which is a fault in it's self as the screen should only be blank if the trailer is not connected. Then when the screen did light up, the message said "Parking Brake Set". I'm 99% sure the controller is toast!
Sumo Springs
Bilstein Shocks
BobWanderer
A very good possibility
2006 TE450 Husky
