Tire time! No china bombs
Madhatter1
39' Fuzion triple axle 15K loaded. Been using Maxxis Load D with good results but want to go to a load range E. 225/75 15". Anyone hauling long distance and heavy that cam make a recommendation for what works these days?
Thanks in advance.
33 REPLIES 33
walker111
Keeping an eye on this as I may buy tires soon. Bought a 2014 Voltage 3305 recently and is in great shape as it should be. The tires are 235/80R16. Name escapes me but starts AK......
They show some wear but ok. Trailer weighed is 12700 and know I will have 1500 more in there towing and will upgrade tires in the future. It is double axle.
Keep recommendations coming....
Frankandbeans
I went with some LT Cooper's in the the standard 16" tire size (285/80/16E I think? Whatever the really common size is). Haven't had a problem with them and am very happy with them.
lincster
16" LT tires is the only way to go.
My buddy only got 3 years out of a new set of Maxxis tires. He was disappointed.
2022 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
kevden
A couple of the 15" china bombs on our trailer were bulging all the way around in the tread last summer. I bought 16" silver steel wheels for $42 each from etrailer. Com. I had uniroyal hd/h load e 10 ply lt tires put on them and the trailer is more stable. Towed it from maine to n.c and back the tires ran cooler on the highway than the china bombs. I check the tires and hubs at every stop with a ir thermometer.
2012 Keystone Outback 312bh
2003 GMC Yukon XL 2500 4X4 Quadrasteer
2010 VW Routan
2007 Chrysler Pacifica AWD
lawnspecialties
Saw this a week ago in the fifth wheels section. I like the selection
Trailer Tires & Wheels
Madhatter1
Wow, thanks for all the responses. I checked the trailer today and I have plenty of room for 16" wheels so may just do that. As for china bombs, well........been china bombed and never again. Maybe they are better now but I'll give then 20 years to prove that out. Going to look at the Firestones. E rating is max I need.
Any sites that sell decent 16" wheels?
Thanks again.
fla-gypsy
Maxxis makes an E rated tire in 15". You said they have performed well.
lawnspecialties
Probably my favorite E rated tires are the Westlakes. Many Forest River haulers come with them. I've had 235/80/16s and they've done really, really well. I know they make E rated 15s but not sure if their performance is any less.
My new hauler is being picked up next week and I went ahead and had them put G614s on it.
nayther
sunnybrooktoyhauler wrote:
I have a triaxle trailer also. I was blowing rear tires all the time. Went to the Firestone transforce lt tire. Knock on wood no blowouts for the last 3 years. Something to ponder. Good luck
I was running Maxxis, two blowouts but they were a bit old. Went to the Firestones on recommendation from my tire guy, so far so good.
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
spadoctor
I agree the "china bomb" is over stated. There are millions of these on the road with no issue. Having towed over 250000 miles only failure was a US made Goodyear. I have friends that have equipment trailers....the chinese ST tires last the same as a US made tire and those trailers take a beating'
sunnybrooktoyha
brirene
Sorry, but I think the whole "China bomb" thing is overblown (no pun intended), especially in the last several years. When was the last time you saw a post about it? I got 5 years and many thousands of miles from my previous MIC Marathons, have replaced them with Carlisle R/H. Tows nicely and I expect good service from these as well. Get a load range higher than the originals, maintain and cover them. YMMV.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
time2roll
Get LT rated for the full GVWR. Probably need 16"+ wheels.
N-Trouble
Do yourself a favor and upgrade to 16" wheels. More/better tire options in that size.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
