โNov-25-2014 04:24 PM
โDec-06-2014 09:10 AM
Itching2go wrote:Bowti wrote:kakampers wrote:schlep1967 wrote:
Do yourself a favor. Ignore anybody that tells you that you should see daylight between the plate and the pinbox. Look at the pin on the pin box. It looks something like an upside down "T". The latch part of your hitch fits between the the lip at the bottom and the flat at the top. If you lift the trailer until you see daylight you can pinch the latch between the bottom lip and the underside of the plate.
When hitching you want the pinbox to hit about the middle of the plate and ride up the plate and into the slot. When it goes in the the curved jaw will snap into place behind the pin.
When unhitching you want to raise the trailer taking most of the weight off the suspension of the truck. Make sure to chock the trailer wheels at this point. Then put the truck in reverse and ease back. Set the parking brake. Then put the truck in Park. Now go see how easy it is to unlatch the hitch. Unhook cord and brake safety cable and ease the truck out from under the trailer.
Excuse me...we've been using Pullrite hitches for almost nine years...have ALWAYS lifted the pinbox until we see a sliver of daylight...have NOT had one issue with this procedure, and have NEVER had it pinch or bind!!
This may have worked for you, as maybe you have been very careful to not lift the pinbox to a binding condition, but why do this and take the chance of binding/ damaging the jaws?
Also remember all these hitches have different thicknesses to the jaws and some might bind more easily, especially if they are using 1/4 inch Teflon lubrication plates.
Good point on the teflon lube pad. I found that while I was able to lift the kingpin slightly above the saddle before I started using a lube pad, that additional 1/4 inch was enough to cause some binding. Now, I raise/lower the kingpin only far enough when hitching or unhitching, that it rides up/down the saddle. Haven't had any binding with my Pullrite since. Having said this, I do need to move the truck a bit to take the tension off before I can easily pull the handle and release the jaws. Minor inconvenience, though, and I really, really like that hitch.
โDec-06-2014 09:07 AM
โDec-06-2014 07:53 AM
โDec-06-2014 07:04 AM
โDec-06-2014 05:10 AM
โDec-06-2014 05:08 AM
โDec-05-2014 02:50 PM
โDec-05-2014 02:14 PM
โDec-05-2014 02:13 PM
โDec-04-2014 01:58 PM
โDec-04-2014 06:23 AM
โDec-04-2014 04:31 AM
schlep1967 wrote:This is EXACTLY how I have been doing it and no more problems. I usually don't need to put it in reverse during the process.
โDec-04-2014 03:16 AM
ol Bombero-JC wrote:schlep1967 wrote:
Ignore the first sentence!
The "anybodys" are referring to UN-hitching.
โDec-03-2014 10:06 AM
