Mar-11-2017 07:20 PM
Mar-16-2017 07:09 AM
otrfun wrote:
Some hitches adjust from 13-17 in. while others adjust from 17-21 in. Have you determined what range of adjustment will best level your rig?
The "best" hitch is not the best hitch if your hitch doesn't have the proper range of adjustment to level your rig.
Also, depending on how low your king pin assembly sits in the bed (relative to the bed rails), it's possible to have the rear of the king pin assembly hit the tail-gate or bed rail when some sliders are activated.
Mar-15-2017 09:03 PM
Mar-15-2017 08:40 PM
Mar-15-2017 06:04 PM
Wild Card wrote:Searching_Ut wrote:N-Trouble wrote:sin cal hd wrote:
Been around the .net for sometime the weight police like to poke their noses in where they weren't asked. But, its all good.
Thanks guys. B&W's are heavy units to move around. I know some disassemble I see a lot of trucks with them and they are expensive. I do like their campanion slider with the factory puck turn and twist.
I do like auto slides. Not much of a fan of super glide do to the capture plate. Thats why Im leaning toward a demco.
Never heard of Anderson. The goose neck attachments I never understood why people use them. There seems to be a lot of torque from the fwd and back motion from stopping and accelerating.
I didnt look at the front cap if it has radius corners or not. Something to look at during pdi.
Edit: there is some radius to the cap.
Curt is another slider Im looking at.
Reese on their site shows an auto slide but no info.
Do some research on the Andersen. Its not a GN in the typical sense. It does NOT put additional stresses on the trailer like your speaking of with a traditional GN
Its been one of the most popular/fastest growing hitch the last couple years.
Actually, the Andersen can damage your pin box, as I learned the hard way. Seems Andersen knows about it as they've built shims to prevent it but they play dumb, blame the pin box, and develop communication issues if you do have problems. I really wish I had gone with the B&W in the first place. Much better hitch, albeit a real pain in the back to move around.
Do tell more.
Mar-15-2017 11:00 AM
Mar-15-2017 07:59 AM
Do tell more.
Mar-15-2017 04:44 AM
Mar-15-2017 04:40 AM
Mar-14-2017 09:33 PM
CJW8 wrote:
I love my Pullrite superglide but it is heavy. I either use my front end loader or usually an engine hoist to remove it and install it. Even with the auto slider and a rounded nose trailer, I still get within 4 inches of hitting my cab in a sharp turn.
Mar-14-2017 06:47 PM
Mar-14-2017 05:29 PM
Mar-13-2017 10:59 PM
Mar-13-2017 02:42 PM
sin cal hd wrote:lightning driver wrote:
I tow a 14K lb 37 ft KZ Montego Bay. Loaded it is very close to 20K. I have an Airsafe Omni 20. I'm not the weight police but I would recommend stepping up from your 16K hitch to a 20K hitch. I like the Air Hitch. Much easier on the truck. I tow with a 1999 F550. I bought it years ago to carry my 11 ft cabover while towing my Rhino on a flat bed trailer.
http://airsafehitches.com/
My apologizes I missed you wanted a slider hitch.
I'm not familiar with sliders. What does the slider do for you?
Your trailer, is it 14k unloaded with 6k cargo? Or are your gross 14k with 6k over your limit? I have no intentions on being more than the legal weight of the trailer.
The slider hitch allows the trailer to be positioned away from the cab during a turn.
Mar-12-2017 09:01 PM
