Exhaust Brake Usage??
supercub
When descending a grade where you're using your exhaust brake, once slowed, to below your desired speed, do you turn off the the exhaust brake and accelerate and then turn it back on......or do you leave it on, and use the throttle to accelerate a little. I was just descending a 6% grade, had the exhaust brake on......and slowed to below 55mph and it's still slowing....I usually turn off the exhaust brake and let it accelerate up to 60 or so, then turn it back on.......but was wondering if I should leave it on and use the accelerator. What's best? Pros and cons? does it matter which you use? Thanks
Brian
14 REPLIES 14
JimM68
ours is not actually an exhaust brake, I think in 2008 it was all worked into the variable vane turbo?
But it works as a previous post described... off the throttle, it does its thing. touch the gas, it shuts off.
I use it a lot. I generally turn it off when driving thru towns, it's just too radical. Out of town, I use it. Typically, even if it is off, I'll switch it on going off a freeway ramp, the help braking is good.
Once when shopping, I test drove a guys Jayco Senenca. (super C with duramax and Allison) I shut off the exhaust brake at one point to just let it coast.... owner had never turned the exhaust brake off! Those things, u let your foot off the gas, they stop like they have hit a wall if the exhaust brake is on....
I generally leave mine off unless I need the braking, but am not shy about turning it on.
Jim M.
2008 Monaco Knight 40skq, moho #2
The "68"
My very own new forumfirstgens.com
My new blog
gfs1943
I learned to love the exhaust brake this past summer. We drove the Crows Nest Highway westbound across the Rockies and Cascades in Canada, then I80 and I70 eastbound from California to Kansas. There are some 6% to 9% downgrades on the Crows Nest. For example, on the westbound descent into Osoyoos, BC, with the exhaust brake on, I only had to briefly tap the service brakes three times. If I get too slow going downhill, I just feather the throttle; that allows the transmission to upshift and disengages the exhaust brake. Driving the mountain passes was a piece of cake.
gfs1943
USAF, Retired (1962 - 1983)
2006 Monaco Diplomat 40PRQ
2006 Honda CR-V
cbeierl
My exhaust brake is configured to operate in conjunction with the cruise control. With exhaust brake and cruise control both on if the vehicle speed gets a couple mph above the set speed the exhaust brake comes on, BUT the transmission doesn't down shift. If the speed continues to increase a few more mph THEN the transmission is commanded to down shift, thus getting the full benefit of the exhaust brake. When the speed has dropped back to the set speed the exhaust brake turns off (and the transmission upshifts if necessary).
Thus you get the benefit of 'coasting' with the cruise control along with fully automatic activation of the exhaust brake.
Chris Beierl
2005 Winnebago Vectra 36RD
J-Rooster
Brian, when I was driving over the road (I'm now retired) in my Peterbuilt, I alway's left my Jake Brake on. Except when driving in ice or compact snow depending on the road conditions. There would be times when I would turn just one jake head on in adverse conditions usually in very dry snow in Eastern Washington and Alaska. Great Question! Take Care, Rooster
mowermech
MrWizard wrote:
My exhaust brake is not Pac Brake
Mine is the "D-Celerator"
There is a main on off switch and a switch on the throttle pedal
With the main On, the brake activates when I take my foot off the throttle, and deactivates when my foot touches the throttle
Very easy to control downhill speed
I don't even have to press down on the throttle
The touch of my foot on the throttle is enough to release the exhaust brake with out giving it throttle
That's the way the Jacobs Rambrake was set up in my old '94 Dodge 3500. It worked GREAT, IMO. I would not want it any other way.
CM1, USN (RET)
2017 Jayco TT
MrWizard
Moderator
Moderator
I can explain it to you.
1997 F53 Bounder 36s
supercub
I've never driven anything with a retarder....I'm not complaining.......I love my exhaust brake. I seldom touch the brakes, it's one of the really nice things over a gas powered motor home.
Brian
mike_brez
This is were retarders shine.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
bluwtr49
I pretty much leave the exhaust brake on high all the time unless I'm using cruise control.
A very light touch on the go pedal disengages the exhaust brake an letting re-engages. I don't use the service brake unless I need more stopping power so just plan ahead.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
ScottG
Use it just like the service brakes - on when you need it and off when you slow too much.
wolfe10
And, I do the opposite in the mountains-- I use the switch to turn it on/off as needed.
When the throttle is closed, you are using ZERO fuel. Using the throttle to turn off the exhaust brake works fine, but uses some fuel to do it.
Agree, in stop and go traffic, I leave it on and use the throttle.
Either method works and is fine as far as the machinery.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
MarkTwain
Brian
I leave my exhaust brake all the time. Around town, I figure it saves wear on my brakes.
DSDP_Don
"supercub".....The down side of an exhaust brake is that you can't regulate the downhill speed. When I had my Diplomat, I left the exhaust brake on and if my speed got too slow, I just gave it a little throttle.
An exhaust brake can be set to a couple of different configurations. Originally, on my Diplomat, the exhaust brake was on if the switch was on and my foot was off the throttle. I later had a computer change done so that when the switch was on, my exhaust brake didn't engage unless I stepped on the brake pedal. When going down a grade, this allowed me to tap the throttle, which would disengage the exhaust brake and the coach would coast. This seemed to make it easier to manage grades. This change is done in the ECM, but not all years can be changed.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
YC_1
With my rv the exhaust brake is rarely turned off. It disengages below a certain speed.
H/R Endeavor 2008
Ford F150 toad >Full Timers
Certified Senior Electronic Technician, Telecommunications Engineer, Telecommunications repair Service Center Owner, Original owner HR 2008
